No access to home server
witsok
So I have set up a home server on ubuntu.
Then I installed Direct Admin with Apache, mysql etc.
The router has a static public IP.
The server has the static IP of the router.
There is another local IP visible in the DA described as free.
I can trace the router IP using an external service like https://www.yougetsignal.com/
But can't get any successful ping of the router from the local network.
The server is not visible on the internet either.
What do I miss?
Witold
I don't understand, you say you can trace the IP using an external service, then you say the server is not visible on the internet. Has the domain name populated? Are you sure your firewalls are allowing you to connect to the server? Are you using a residential or business internet service? Are you sure they allow incoming connections to ports 80 or 443?
true
the website is not visible though dns should be populated by now
btw, I'm using dns names created by DA.
ns1.server-ip.da.direct
these names have been registered with my registrar
when I trace dns names they point at the router's/server's IP
I think so
FW on my router or the server.
Frankly, I jave no idea.
I opened ports 80 and 22 on the router.
But don't know what else I can do.
Business connection
yes - but with your domain name...
This I know to be true, I do not run my own name servers through DA,. so I will be of limited help
server's hostname also is generic like server-ip.da.direct
should it also be changed to mydomain.com
That's not enough, you also need to forward -at least- port 53, 853 and 443.
You mean the ip's have been registered as you are not the owner of the da.direct domain.
Read what others said about that.
Change your nameservers and hostname to your own domain.
So for example server.domain.com and ns1.domain.com and ns2. domain.com if you want to use your own nameservers.
I found this list of ports
do I need to open the same ports on my router with public IP
or only in DA firewal
Do I need to add an A record for server in server.mydomain.com?
one more thing.
when I try to log into the server using putty I can't use the router's public IP
only the local IP works for me
it it normal?
one more thing.
it it normal?
There could be multiple things eg;
Port is not forwarded (correctly)
You ISP blocks you from visiting your own IP (i'm from the netherlands and saw this happen to multiple people where i installed IP camera's with one specific provider)
Way to test it : setup a hotspot with your phone and try it (while on 4g/5g) or straight from your phone on 4g/5g.
Both. But in DA firewall they are normally opened during Directadmin installation.
But this does not make it accessible from the internet if your behind a router due to the routers NAT and internal LAN ip's. So yes, for all services you want to use, you have to open those in your router with public ip and forward them to the ip of your DA server.
Possible, but it's better to create a seperate DNS entry via the DNS adminstration for server.mydomain.com so not as user.
This makes some other things easier, like getting SPF and DKIM record for the hostname so system and php mails don't run into issues.
Login how to the server, via SSH or via port 2222?
This can have 2 reasons.
1.) You don't have set the port forwards correctly
2.) Your home router does not support nat-loopback otherwise called hairpin.
if you just got only public ip but Router still same as simple home internet, mostly you need port forward on your router.
there have diference between "router for home" and "router for datacenter"
ok. so I've made some changes.
in the router config I found sth like host and put the public IP received from the ISP in there
I made port forwarding from external (router IP/host) to the local IP (the server)
From the local network now I can ping the router (public IP) and the server (local IP)
When I go to https://www.dnsqueries.com/en/dns_lookup.php
The website domain doesn't resolve to the router's IP / the public IP.
When i try to test the ports using just the router's IP / the public IP on
I get that all ports are closed
in DA the server's IP is the same as the router's IP / public IP
maybe now it should be bound to local IP
what do you think?
