AlmaLinux 10 support
JosKlever
Werkhoven, NL
I'm about to get a new server with AlmaLinux and DirectAdmin (Standard license). Does anyone have information about how DirectAdmin runs on AlmaLinux 10, that recently was launched? Any big changes to the software that might have an impact?
My current server (that I will continue to use) is running on AlmaLinux 8.10.
Legacy License will not support AL10 as far I know only full license support RHEL10 system (link).
You can migrate to AL9 with LL
I had already gave the answer RHEL10 is supported then
You added that link later (when I was already replying). Besides the link your answer wasn't relevant to my question.
My question (a bit rephrased) remains: does anyone have actual experience with running AlmaLinux 10 and DirectAdmin already and do you encounter any practical issues or is it production ready?
Right now the biggest problem with RHEL 10 or AlmaLinux 10 is that rspamd does not provide packages for this version (yet). This means DA on RHEL10 systems can only use spamassassin. We expect rspamd to start providing RPMs for newer systems soon.
We also had the report that RockyLinux 10 has problems with CSF in DA Panel (it is not shown there). The issue report is created to developers to check it closer and get fixed.
There is no information at the link you provided that the lifetime license does not support AlmaLinux 10.
@fln
Will Directadmin still work for me (lifetime) after upgrading from AlmaLinux 9 to 10?
@gurek, The legacy DirectAdmin will not work with systems based on RHEL 10 - CentOS 10, Alma Linux 10, RockyLinux 10.
Aagh I was right but could not find the post / link about i
I gave the link so that the topic starter can see RHEL10 is supported by DA, was not talking about type of license
I have now replaced SpamAssassin with RSPAMD on an AlmaLinux 10 system. Unfortunately, I can’t find the RSPAMD control panel. Does anyone have an idea what could be causing this?
I installed AlmaLinux 9 because version 10 isn’t stable yet — that was the deciding factor. Did I make the right choice?
Could you clarify, what issues did you face? Beside the fact it still missing some rpms, the other things seem to be fine)
I decided to install version 9 because I saw some negative feedback about version 10 on webmaster forums and here as well. If version 10 had been stable, I would have chosen that, but I didn’t want to take the risk. I’m not sure if I made the right choice — that’s why I asked.
@Can But what negative feedback did you see? Why would that make you avoiding version 10? It's been running on my new server for a few months now and it's stable (for me). There might be bugs, but version 9 might also have a few bugs left (just like any version), so that's not a blocking issue.
Nobody can tell you if you made the right choice, because you don't tell what would be a breaking issue for you. So if you say software isn't stable, give us proof/arguments.
I installed version 9 based on the comments I read — I don’t have any personal experience myself. So I can’t really prove anything. If I had known, I would’ve gone with version 10.
Do I need to do a clean installation to move from 9 to 10, or is it possible to upgrade directly?
