How do I install ModSecurity OWASP CRS Plugins in Directadmin?
webbasica
USA
In Mod Security, the OWASP CRS 4.x have plugins (formerly "exclusion packages"). I'm trying to enable them in my custom modsecurity conf file for Custom Build. Since I'm using OpenLiteSpeed, this is the file:
/usr/local/directadmin/custombuild/custom/openlitespeed/conf/httpd-modsecurity.conf
According to the CRS documentation, it's as simple as creating a directory, and adding he rule files:
Include crs/crs-setup.conf
Include crs/plugins/*-config.conf
Include crs/plugins/*-before.conf
Include crs/rules/*.conf
Include crs/plugins/*-after.conf
However, I don't know how to accomplish this using the Custom Build conf file (httpd-modsecurity.conf)
# Default recommended configuration
SecRuleEngine On
SecRequestBodyAccess On
SecDefaultAction "phase:2,deny,log,status:406"
SecRequestBodyLimitAction ProcessPartial
SecResponseBodyLimitAction ProcessPartial
SecRequestBodyLimit 13107200
SecRequestBodyNoFilesLimit 131072
SecAuditLogFormat JSON
SecPcreMatchLimit 250000
SecPcreMatchLimitRecursion 250000
SecCollectionTimeout 600
SecDebugLog /var/log/httpd/modsec_debug.log
SecDebugLogLevel 0
SecAuditEngine RelevantOnly
SecAuditLog /var/log/httpd/modsec_audit.log
SecUploadDir /tmp
SecTmpDir /tmp
SecDataDir /tmp
SecTmpSaveUploadedFiles on
# ModSecurity Core Rules Set and Local configuration
Include /etc/modsecurity.d/*.conf.main
Has anyone installed OWASP CRS plugins in Directadmin?
I have exactly the same question (for Apache webserver). For now I've pinned my DA install to keep OWASP v3 because of this.
With OWASP v3 I have some custom settings in /usr/local/directadmin/custombuild/custom/modsecurity/conf/ that get included every time the httpd confs are rewritten.
With OWASP v4 it's unclear for me if this will still work since, with default settings, it would require overwriting directories?
Since the build script is now included in the DA binary it's impossible to find out without just testing and I don't want to try this on my live server....
Some kind of "how to" from DA would be nice...
I've done a quick experiment myself.
The OWASP directory layout of v4+ is roughly the same as v3.
The DA httpd-modsecurity.conf stays the same.
So you should be able to enable plugins by creating two files in /usr/local/directadmin/custombuild/custom/modsecurity/conf/ that load your plugin files "before" and "after".
OWASP suggests using REQUEST-900-EXCLUSION-RULES-BEFORE-CRS.conf and RESPONSE-999-EXCLUSION-RULES-AFTER-CRS.conf.
I haven't tested this myself (and still am on v3)
This is for Apache webserver
I am curious if there are people who implemented these plugins successfully on DA with Apache. The ModSecurity logs show that the OWASP ruleset is doing good work, but it also breaks editors like Elementor and plugins suchs as Roundcube.
I disabled ModSec altogether, WordPress was becoming more incompatible every day. Still waiting if we get this functionality someday to give it another try
That's a pity. I really do like the idea of managing this on server level instead of website level with Wordfence doing multiple scans breaking the server.
I'm trying to use OWASP rules in the past and find out it too much breaking application, so I switch back to COMODO rules. Even phpmyadmin can't use at all.
Comodo rules have a little false positive better than OWASP.
Yes, but they are outdated and the ruleset is not in development anymore?
I've found some time to test a OWASPv4 plugin setup.
What I did:
  1. I've created a custom directory /opt/modsecurity.plugins/ where my plugins live;
  2. I created a dummy empty plugin in /opt/modsecurity.plugins/ (to handle Include directives when you don't have IncludeOptional), see setup below;
  3. In /opt/modsecurity.plugins/ I did a git clone <plugin> for the plugins I use (WordPress, phpMyAdmin, Nextcloud, DOS protection)
  4. In /usr/local/directadmin/custombuild/custom/modsecurity/conf/ I created REQUEST-900-EXCLUSION-RULES-BEFORE-CRS.conf and RESPONSE-999-EXCLUSION-RULES-AFTER-CRS.conf
  5. The relevant contents of those conf files are below
  6. Do a da build rewrite_confs
  7. That's it :)
REQUEST-900-EXCLUSION-RULES-BEFORE-CRS.conf content
Apache config:
# OWASP custom settings, eg. put your generic settings/modifications here
# -- [[ Paranoia Level Initialization ]] ---------------------------------------
SecAction \
  "id:900000,\
   phase:1,\
   nolog,\
   pass,\
   t:none,\
   setvar:tx.paranoia_level=1"
# v3 rules
# Skipped when crs_setup_version >= 400
SecRule TX:crs_setup_version "@ge 400" "id:30001,phase:1,pass,nolog,skipAfter:DKZR-OWASP-V3"
SecRule TX:crs_setup_version "@ge 400" "id:30002,phase:2,pass,nolog,skipAfter:DKZR-OWASP-V3"
# To make testing/switching easier, put any OWASPv3 rules here
SecMarker "DKZR-OWASP-V3"
# v4 rules
# Skipped when crs_setup_version < 400
SecRule TX:crs_setup_version "@lt 400" "id:40001,phase:1,pass,nolog,skipAfter:DKZR-OWASP-V4-BEFORE"
SecRule TX:crs_setup_version "@lt 400" "id:40002,phase:2,pass,nolog,skipAfter:DKZR-OWASP-V4-BEFORE"
# All included files are part of this skipAfter block
IncludeOptional /opt/modsecurity.plugins/*/plugins/*-config.conf
IncludeOptional /opt/modsecurity.plugins/*/plugins/*-before.conf
SecMarker "DKZR-OWASP-V4-BEFORE"
RESPONSE-999-EXCLUSION-RULES-AFTER-CRS.conf content
Apache config:
# v4 rules
SecRule TX:crs_setup_version "@lt 400" "id:41001,phase:1,pass,nolog,skipAfter:DKZR-OWASP-V4-AFTER"
SecRule TX:crs_setup_version "@lt 400" "id:41002,phase:2,pass,nolog,skipAfter:DKZR-OWASP-V4-AFTER"
IncludeOptional /opt/modsecurity.plugins/*/plugins/*-after.conf
SecMarker "DKZR-OWASP-V4-AFTER"
Empty plugin setup
  1. Create directories /opt/modsecurity.plugins/00-empty-placeholder-plugin/plugins/
  2. In that directory, create three empty files: empty-config.conf, empty-before.conf and empty-after.conf
Git clone a plugin
For example the phpMyAdmin plugin, after cd /opt/modsecurity.plugins/ you run: git clone https://github.com/coreruleset/phpmyadmin-rule-exclusions-plugin.git You get a plugin directory phpmyadmin-rule-exclusions-plugin.
You must now decide if you want to use de main/master branch or a specific version (tag). See the git manpage on how to do this.
  • Like
Reactions: r3y
PS. I only did a short test with v4 as I only have one server. So back on v3 in production time, hopefully can do some more testing later.
But in the short time that I used v4 all WordPress and Nextcloud instances and phpMyAdmin worked fine.
  • Like
Reactions: r3y
Are you sure that phpMyAdmin is working? Have been trying this for the last two hours but can't get it done. Looks fine at first and you can select a table to the left, but after that, the page becomes unresponsive and you can't change anymore. Here's the error from the ModSecurity log:
        "message": "PHP Injection Attack: High-Risk PHP Function Name Found",
        "details": {
          "match": "Matched \"Operator `PmFromFile' with parameter `php-function-names-933150.data' against variable `REQUEST_FILENAME' (Value: `/phpMyAdmin/js/vendor/sprintf.js' )",
          "reference": "o23,6v4,32",
          "ruleId": "933150",
          "file": "/etc/modsecurity.d/REQUEST-933-APPLICATION-ATTACK-PHP.conf",
          "lineNumber": "313",
          "data": "Matched Data: printf found within REQUEST_FILENAME: /phpMyAdmin/js/vendor/sprintf.js",
          "severity": "2",
          "ver": "OWASP_CRS/4.12.0",
          "rev": "",
          "tags": [
            "application-multi",
            "language-php",
            "platform-multi",
            "attack-injection-php",
            "paranoia-level/1",
            "OWASP_CRS",
            "capec/1000/152/242"
          "maturity": "0",
          "accuracy": "0"
What I did:
  7. That's it :)
Apache config:
SecAction \
  "id:900000,\
   phase:1,\
   nolog,\
   pass,\
   t:none,\
# v3 rules
# v4 rules
Apache config:
# v4 rules
Empty plugin setup
Git clone a plugin
This is the most elegant way to do it! Thank you so much! This doesn't break DA Custombuild or version updates!
Only problem is that
IncludeOptional isn't supported by OLS, it needs to be replaced by Include directive
Quite sure... I think for phpMyAdmin you need to use the "master" branch of the plugin, not the v1 tag.
How do you find the DOS protection plugin? Is it actually useful?
And that brings me to another question: How do you maintain custom configuration settings for the plugins in the git directories? Editing the *-config.conf file will be a local modification as far as git is concerned, which means a later git pull might not be as smooth as one would like..
I have mixed results with the DOS protection of coreruleset. It does block some "1 IP" flood attacks but not all. It's hard to monitor when it does or doesn't "trigger" a block.
I'm still on OWASPv3.7 for production :rolleyes: but I think I would put custom modifications in REQUEST-900-EXCLUSION...conf either above or directly below the IncludeOptional /opt/modsecurity.plugins/*/plugins/*-config.conf statement (depending on the contents of the plugin config file you might want to disable or "overwrite").
See the explanation at the top of REQUEST-900-EXCLUSION....conf.example.
