July 2026 – Effectively the end of the DirectAdmin Legacy License
Please select the option that best reflects your current situation:
  • Total voters
    49
virtio
Netherlands
July 2026 – Effectively the end of the DirectAdmin Legacy License​
For anyone who wasn’t aware yet: July 2026 effectively marks the end of the DirectAdmin Legacy License — at least, that’s the unavoidable conclusion after our recent discussions with DirectAdmin.
Over the past week, we had an in-depth exchange with the DA team about the future of the Legacy License. Since many providers/users appear unaware of what is coming, we want to share a clear and transparent summary to help others plan responsibly.
How this started
The conversation was triggered by a simple fact:
  • MariaDB 10.6 reaches community EOL in mid-2026.
  • Legacy installations cannot upgrade to MariaDB 10.11+ via CustomBuild, because newer versions are restricted to the new DA licensing model.
In other words: when 10.6 hits EOL, Legacy systems can no longer run a supported MariaDB version inside the CustomBuild ecosystem, which is how the vast majority of DA users maintain their LAMP stack.
What DirectAdmin clarified
After several messages back and forth, DA confirmed the following points clearly and unambiguously:
1. Legacy should now be treated as effectively hard EOL.
Although previously described as “sunset” or “soft EOL,” DirectAdmin clarified that, in practice, Legacy is a static product.
No further development will be added — not for MariaDB, not for OS support, not for any LAMP components.
2. MariaDB 10.11+ will not be made available on Legacy — now or ever.
This includes all maintained versions beyond 10.6.
3. DA acknowledges Legacy will become unusable for most production environments.
Their own wording:
“We acknowledge this will make licenses useless for most, but that’s the intent behind lifecycle management/EOL.”
4. The only alternative is using OS-repo MariaDB/MySQL packages.
However, these are typically older, behave differently, and are not aligned with how DA environments are normally managed via CustomBuild.
5. More “technical walls” are expected — by design.
MariaDB is simply the first.
Newer OS versions (RHEL 10, Debian 13, etc.) are also unsupported and will remain incompatible with Legacy.
Why this matters
For years, the industry understanding of the Legacy License was:
  • still fully functional,
  • without the newer features of the updated license model,
  • and to be retired at a later, clearly announced EOL date.
Not as a license that would become effectively non-viable due to blocked updates of core security-critical components.
Many providers — including larger ISPs — were unaware that MariaDB 10.6 EOL forces a de facto end-of-life for Legacy by July 2026.
In operational reality, this means:
Legacy becomes unsuitable for commercial workloads from mid-2026 onward.
What this means for you
If you’re still running DirectAdmin Legacy:
  • Migration will be required — sooner than expected.
  • Assume Legacy is already operationally EOL.
  • New deployments on Legacy should be avoided for security and compliance reasons.
DirectAdmin did provide full clarity once pressed with direct questions — but only then. Given how many users still operate under outdated assumptions, sharing this information openly feels necessary.
Clearer communication would help the ecosystem
A simple, explicit statement such as:
“Legacy is now effectively hard EOL. No further updates of core components such as MariaDB will be provided. Expect full deprecation by mid-2026.”
…would prevent many partners and users from being caught off guard.
Closing – and a very important note
This post is not meant as criticism of DirectAdmin’s decision to evolve its licensing model. A product lifecycle is normal, and DA is absolutely entitled to modernise.
More importantly:
We continue to be strong supporters of DirectAdmin.
We still consider DA the best control panel in the market - lightweight, stable, fast, and with a far superior operational experience compared to many alternatives. Nothing about this situation changes the fact that DA remains our preferred panel, and the one we recommend to customers.
Our comments are purely about clarity:
the first hard technical wall (MariaDB) accelerates the practical end-of-life of Legacy much earlier than many expected.
If this summary helps you prepare your infrastructure or update your customer communication, then it has served its purpose. Also, please check the poll.
MariaDB 10.6 does not mean directly end of Legacy DA, there are still server that are running MySQL 5 without problems as long you don't have open your SQL to the world you can work with 10.6 for al least few years,
Yes no updates but I am sure that many software will still support 10.6.
I think that most of the people will migrate after OS is EOL and not MySQL
Correct, however, there might be a slight chance that Directadmin would provide an option so the OS can keep the MariaDB installation up to date.
Almalinux 9 has updates for MariaDB 10.5 until 2032 theoretically.
That would mean that if we would downgrade to MariaDB 10.5 the OS could provide us update without further development requirement of DA and it would still be up to date.
Maybe @romans can enlighten us if there might be plans providing this for us to have the MariaDB updates switch to the OS.
As for the rest of your article. That is already known for several years. So people have enough time to make changes or choices.
Thanks both for your replies — much appreciated.
@Active8
You’re absolutely right that running an older database version doesn’t mean a system immediately becomes unusable. Many environments continue to run fine for quite some time, especially when the database isn’t exposed publicly. Anyone is free to make that choice, and for some setups that will be perfectly acceptable.
Our point is mainly that the first unavoidable blocking point for many providers appears earlier than expected — not because MariaDB 10.6 stops working overnight, but because most hosting companies rely on supported, actively maintained database versions as part of their operational and security policies. For those providers, the practical EOL arrives as soon as they can no longer keep the LAMP stack aligned with their standards. That’s the angle from which this post was written.
@Richard G
The idea of using OS-maintained MariaDB packages is indeed a potential technical workaround, and if DA considers enabling such an option, that would be valuable information for many users. We’d gladly hear more from @romans if that’s something being explored. But it would still represent a shift away from the CustomBuild-based workflows that most providers currently depend on.
Regarding the point that “this has been known for years”: absolutely — but based on the conversations we’ve had with several ISPs in the past weeks, it seems clear that quite a few people were unaware of the practical, not just theoretical, implications. Hence this topic to make sure everyone has the same information and can plan accordingly.
To be clear:
Everyone is, of course, entirely free to approach this transition however they prefer, based on their own risk profile, business needs, and operational policies. This post is simply intended to share the insights we received directly from DA, so those who want to plan proactively can do so with full information.
As a final note, I’d like to add our broader view on the matter.
In our opinion, it would ultimately be healthier — both technically and strategically — for DirectAdmin to give the Legacy edition a clear and hard end-of-life date. Legacy is deprecated software, and history shows that as long as something deprecated remains available, there will always be people (and even entire organisations) who continue relying on it far past what is wise or secure. A hard EOL gives clarity, protects users from themselves, and enables everyone to plan properly instead of delaying the inevitable.
A wise man once illustrated the concept of EOL sunsetting with this metaphor:
“EOL sunsetting is like a plane making a soft landing and giving everyone plenty of time to deboard. Some exit quickly, others take longer. But when someone asks, ‘If I stay, what do I get?’ - it misses the point. The goal is to deboard, not to plan for continued use after landing.”
I think that captures the situation perfectly.
Legacy served its purpose for many years, and it did so extremely well. But eventually, it has to be retired - and that’s ultimately better for DirectAdmin, for providers, and for end-users. Clear timelines and a firm EOL would help everyone move forward confidently.
Unfortunately I don't agree with this. DA has done his best just to not do this so people could have a bit longer from their lifetime licenses, especially the ones bought at a later time.
Ofcourse I agree that some will use ancient stuff, but it's not DA's task to protect users against this. There are even people running older DA versions with php 5 (not being cloudlinux) and probably because of customer pressure/requests, DA made it possible to run ancient non-supported php versions since last year if I'm correct with the option to run multiple php versions at the same time.
So it is already providing unsecure things.
But it is what it is and it's the responsibility of the hoster/admin to decide wheater they want their systems upmost secure or even insecure.
So let the admins decide.
Because as long as php and apache etc. keeps updated, for the time being these servers can still run with a minimum risk, there is no need for a hard exit, which will also raise loads of complaints which they are not waiting for.
Confidentially working forward can also be done without those timelines and even then people will always keep using EOL software "because their customers don't want to or say they can't upgrade for financial reasons".
There are really contrasting positions on running EOL software.
For example, we had a hard EOL date for DirectAdmin on FreeBSD. It was January 2022 (almost 4 years ago). It was hard EOL, no DA updates, no 3rd party software updates, nothing at all. Still to this day have ~70 FreeBSD servers running and actively using DirectAdmin. We even backported a couple or critical security fixes for them, because they are publicly reachable.
And I get chills down my spine every time I look into RHEL/CentOS 6 usage statistics 😞.
There is no need to run a database server on the same server with directadmin at all. You can always use a remote database server with any version per your preferences. Just keep in mind that you won't be able to manage the database server in DirectAdmin. That's it)
Yep I know, but then it is what you say, you can't manage the database in Directadmin. So it would be easier if we could downgrade to 10.5 and then have the OS keep doing the updates and we could keep managing the database from Directadmin.
No special development of DA was required than anymore either and we could keep using MariaDB too without external fuzz which is not always possible for everybody.
As simple as
1.) one needs a second server/vps to put the database on, which not everyone can afford or want (just for database)
2.) you loose the connection to manage it from DA so you have to make all databases manually? Or can this still be done via Directadmin?
3.) you then will depend on external connections, which can cause optional speed loss and even connection losses and if you don't watch out extra intrusion risks.
At this moment MariaDB is updated via rpm's anyway, what is the big issue for let us keeping that on the current server but then just have the rpm's updated during OS updates?
Every solution has its own pros and cons. I offered one possible. If it does not fit your needs, it's OK.
You can install any database version on the same directadmin server. I don't know what directadmin will do, when a non-supported database server version is discovered. I never tested it yet. I will probably do some tests, when I have time)
A couple of years ago I used the DA hooks to mirror the creation/removal of databases and users to a remote galera cluster. This might work with a second mariadb instance on the same server.
Might.... but still the other counter arguments are still present, as is my question what be so bad with my idea to have DA to allow us to downgrade to MariaDB 10.5 and then have the OS support the updates.
If I remember correctly this was tested, should be even a thread about it somewhere here. Somebody installed MariaDB 10.11 manually and got a notice that this was not allowed.
Maybe it's possible to install some other database, but then the connection with DA is lost again (managerble, user can create databases etc).
So that is why I ask about the idea previously made somewhere, to allow the OS updates for MariaDB once 10.6 is EOL. So users can choose either keep running an EOL version or choose your suggestion of database on another server, or downgrade to 10.5 and have the OS keep doing the updates.
Either way, this should be no issue for DA and no extra development. And would make life easy for people who would like to keep things as they are now for a bit longer. Because with the EOL date of Alma 9 in 2032 it's end of story anyway, probably even sooner depending on which updates are coming (or rather not).
If I remember correctly the idea of giving users choice to have the OS do the updates after EOL of the database was under consideration.
It's not that expensive, and you can see how well they're developing, updating, and fine-tuning DA. It's getting better and better.
Thing is, there are nearly bugs/issues every update that need "a fix", kinda disheartening if you have 200+ servers and a few go belly up - meaning downtime and lost revenue.
Not saying a license is expensive, but it does add up, especially if you want to be competitive.
I can imagine that's quite a bit of work, but to be fair, Whether it be DA, cPanel, Plesk or Enhance...... there's always going to be bugs as software is always evolving as is the nature of it. Some of it could be DA, some could be third party software. As regards licensing though, I only have a few licenses, but don't DA offer bulk discounts if you did have, say, 200+ servers? I'd imagine they offer you some sort of heavy discount or it wouldn't be worth it. I'm just glad these aren't as greedy as the cPanel crowd.
Come on, use your legacy license for something else and just buy a real license.
For what else, we only do hosting?
It's only MariaDB which will go EOL and it's not 1 but 6 licenses and 3 servers in use. Switching means 45/month extra (when converting these 3), so with MariaDB from the OS update, we probably can go the last few years until our pension. Most of the developping we don't need and don't use as we don't do now since they are not for legacy licenses.
They still work so no reason to change, it's just that we rather work with up to date Mariadb then EOL. And since it's done via rpm from the OS now anyway, it should be a slight change anyway.
I'm not complaining, just asking! Still happy with the licenses, but for those few years until we stop, we won't go buying new licenses anymore anyway.
I'm sure lots of others will keep using the licenses anyway, if needed with EOL Mariadb or Mysql.
If I was younger I would most likely already have converted the licenses c.q. my collegue or at least several of them. But we're already too old now. ;)
  • Like
Reactions: Hek
Well... one is never too old to learn either and I learned something new today, at least for me this was a bit new how this worked. ;)
Backporting in the OS means nothing more then only in excessive cases (even while EOL), the MariaDB devs would create a security fix after something very very wrong is discovered. Then Almalinux waits until the fix released and after that they will provided it in the updates, the so called backport support.
I always thought that it was like bind, where older versions just are kept up to date and secure via the OS but probably that's working the same way and the Bind/named guys are providing it.
Anyway, these updates via the OS, as of the EOL date, will only happen in exceptional/extreme cases.
And I've also learned that in such case, DA will also provide us with such update via CB, probably faster than the OS will do.
So concluding, it's better not to downgrade to 10.5 because it's not needed for these fixes.
But also that we have to keep in mind that "normal" security issues will not be fixed, neither by the OS nore DA because MariaDB won't fix them (because EOL).
Security wise this means one has to keep in mind that one can keep using it after EOL, but it's not as safe as a non-EOL versions, because only the very worst issues will be fixed and smaller ones won't (even if they are bad for us).
So the idea of having the OS backport these updates, is not nearly the same as working with a secure up to date version!
At least everybody now knows how this works and the risks still involved.
Ofcourse it's always better to work with up to date versions of things, but now it makes sense that it's not really usefull to downgrade to 10.5 and have the OS backport it because DA is as nice (also out of safety and ethics grounds) to give us these same fixes too (if there would be any released).
Make wise choices now. ;)
