DirectAdmin 1.714
fln
Administrator
Staff member
We are happy to announce the release of DirectAdmin 1.714.
DirectAdmin 1.714​
what's this meaning ?
Is it separate unix-socket handle from normal user application ? And normal user can't using PHP to connect to these socket-handle on root account, right ?
It is the same UNIX socket that normal applications use. If MySQL/MariaDB server detects that the other end of UNIX socket (client side) is running as root process (UID 0) then it allows the connection without password.
It works by using the unix_socket authentication plugin for MariaDB or auth_socket authentication plugin for MySQL. For MariaDB the authentication plugin is built-in, for MySQL servers it is loaded by adjusting the MySQL server startup parameters in the systemd service file.
Note: This does not affect existing installations. The code to set-up password-less logins for root is executed only when CustomBuild performs the initial MySQL/MariaDB install (when it initializes the mysql data directory). Old behaviour was to set root account password to be the same as da_user account password. After initial install CB does not touch the root account credentials.
If PHP process is running as root it can connect without password. If it runs under different UNIX user it will not be able to connect as root. The authentication plugin checks for the client process UID (asks the kernel to check to be more precise, so it is reliable and does not require any userspace process checking).
The implementation is trivial, on fresh installs CB executes:
ALTER USER root@localhost IDENTIFIED WITH unix_socket;
or:
ALTER USER root@localhost IDENTIFIED WITH auth_socket;
This single query is enough to replace root account password with password-less mode. It can be used on existing servers. But CB will not do this automatically. For the time being... :).
I already used SFTP (port 23) on a Debian 13 server. For this to work I had to disable FTPS in /etc/proftpd.conf (TLSEngine off).
For the Server SSL Certificate I used the ECDSA-256 (the default of ACME?)
After updating to the latest versions I ran into 2 problems, both causing ProFTPd not to be able to start.
○ proftpd.service - ProFTPD FTP Server
Loaded: loaded (/etc/systemd/system/proftpd.service; enabled; preset: enabled)
Active: inactive (dead) since Wed 2026-11-11 16:50:00 CET; 32s ago
Duration: 73ms
Invocation: 60ea87c2b4ec4d478c47b77bbc99a731
Process: 198634 ExecStartPre=/usr/sbin/proftpd --configtest (code=exited, status=0/SUCCESS)
Process: 198636 ExecStart=/usr/sbin/proftpd --nodaemon $PROFTPD_OPTIONS (code=exited, status=0/SUCCESS)
Main PID: 198636 (code=exited, status=0/SUCCESS)
Mem peak: 2.6M
CPU: 82ms
Nov 11 16:50:00 daintern systemd[1]: Starting proftpd.service - ProFTPD FTP Server...
Nov 11 16:50:00 daintern proftpd[198634]: Checking syntax of configuration file
Nov 11 16:50:00 daintern proftpd[198634]: 2026-11-11 16:50:00,074 daintern proftpd[198634]: mod_tls/2.9.2: certificate '/etc/exim.cert': expected RSA certificate, found EC
Nov 11 16:50:00 daintern proftpd[198634]: 2026-11-11 16:50:00,079 daintern proftpd[198634]: mod_tls/2.9.2: certificate '/etc/exim.cert': expected RSA certificate, found EC
Nov 11 16:50:00 daintern proftpd[198634]: 2026-11-11 16:50:00,094 daintern proftpd[198634] 188.200.21.232: mod_sftp/1.2.0: Server 'ProFTPd': cannot support both FTPS (TLSEngine on) and SFTP (SFTPEngine on) for the same host
Nov 11 16:50:00 daintern systemd[1]: Started proftpd.service - ProFTPD FTP Server.
Nov 11 16:50:00 daintern proftpd[198636]: 2026-11-11 16:50:00,148 daintern proftpd[198636]: mod_tls/2.9.2: certificate '/etc/exim.cert': expected RSA certificate, found EC
Nov 11 16:50:00 daintern proftpd[198636]: 2026-11-11 16:50:00,152 daintern proftpd[198636]: mod_tls/2.9.2: certificate '/etc/exim.cert': expected RSA certificate, found EC
Nov 11 16:50:00 daintern proftpd[198636]: 2026-11-11 16:50:00,168 daintern proftpd[198636] 188.200.21.232: mod_sftp/1.2.0: Server 'ProFTPd': cannot support both FTPS (TLSEngine on) and SFTP (SFTPEngine on) for the same host
Nov 11 16:50:00 daintern systemd[1]: proftpd.service: Deactivated successfully.
After generating a RSA 4096 Server Certificate, this problem was solved. Now I ran into the old problem, I had to disable FTPS again, because FTPS and SFTP can't run on the same installation.
Active: inactive (dead) since Wed 2026-11-11 16:53:29 CET; 4s ago
Duration: 88ms
Invocation: 169df26187954caead6ac57355bd602f
Process: 200739 ExecStartPre=/usr/sbin/proftpd --configtest (code=exited, status=0/SUCCESS)
Process: 200741 ExecStart=/usr/sbin/proftpd --nodaemon $PROFTPD_OPTIONS (code=exited, status=0/SUCCESS)
Main PID: 200741 (code=exited, status=0/SUCCESS)
Mem peak: 2.3M
CPU: 84ms
Nov 11 16:53:28 daintern systemd[1]: Starting proftpd.service - ProFTPD FTP Server...
Nov 11 16:53:28 daintern proftpd[200739]: Checking syntax of configuration file
Nov 11 16:53:29 daintern proftpd[200739]: 2026-11-11 16:53:29,029 daintern proftpd[200739] 188.200.21.232: mod_sftp/1.2.0: Server 'ProFTPd': cannot support both FTPS (TLSEngine on) and SFTP (SFTPEngine on) for the same host
Nov 11 16:53:29 daintern systemd[1]: Started proftpd.service - ProFTPD FTP Server.
Nov 11 16:53:29 daintern proftpd[200741]: 2026-11-11 16:53:29,119 daintern proftpd[200741] 188.200.21.232: mod_sftp/1.2.0: Server 'ProFTPd': cannot support both FTPS (TLSEngine on) and SFTP (SFTPEngine on) for the same host
Nov 11 16:53:29 daintern systemd[1]: proftpd.service: Deactivated successfully.
Do I have to manually reconfigure proftpd on all my servers, because the update breaks the old one? Can this be solved in a different way?
Enrico
@enricovangoor, just disable the SFTP support in proftpd with:
da build set proftpd_sftp_port 0
da build proftpd
It should be disabled by default, unless CB found some config files hinting that it might have been used. Probably because it was disabled not by excluding the proftpd module for SFTP but by using custom configuration.
Duration: 73ms
Mem peak: 2.6M
CPU: 82ms
Duration: 88ms
Mem peak: 2.3M
CPU: 84ms
Enrico
Actually, you can have both and many servers do, mine included.
You may notice that DA version mod_tls.c is enabled in the main part of the config, while the mod_sftp part has its own VirtualHost.You should review your customizations that you have and re-evaluate what's actually needed and what's just a historical burden that you keep carrying over.
Following the recent ProFTPD update from 1.3.9d to 1.3.9e, we started experiencing FTPS directory listing failures across multiple production servers running AlmaLinux 8.
The FTP connection and TLS authentication complete successfully, but directory listings fail with the following FileZilla errors:
Command: MLSD
Response: 150 Opening BINARY mode data connection for MLSD
Error: GnuTLS error -302 in gnutls_record_recv: Error in parsing.
Error: Could not read from transfer socket: ECONNABORTED
Response: 226 Transfer complete
Error: Failed to retrieve directory listing
We compared affected and unaffected servers, all running ProFTPD 1.3.9e, and identified the following pattern:
  • AlmaLinux 8 / OpenSSL 1.1.1k: Affected.
  • AlmaLinux 9 / OpenSSL 3.5.8: Unaffected.
This issue has already been documented and fixed by the ProFTPD developers, under issue #2416:
https://github.com/proftpd/proftpd/issues/2416
The upstream fix is available here:
https://github.com/proftpd/proftpd/commit/3254ac2
Since DirectAdmin distributes and manages ProFTPD updates through CustomBuild, we request that the official upstream patch be incorporated into the CustomBuild package as soon as possible.
a workaround which will revert after update
sed -i 's/^\(\s*\)TLSProtocol.*/\1TLSProtocol TLSv1.2/' /etc/proftpd.conf && systemctl restart proftpd
Thanks for reporting @unihostbrasil. It seems the ProFPTD version 1.3.9e is really buggy. We already had to pick one patch from the upcoming version to make the SFTP module functional.
We will either add another patch to fix the compatibility with old OpenSSL or revert back to ProFPTD version 1.3.9d and wait for all the 1.3.9e bugs to be fixed in the next release.
In general we do not want to keep cherry-picking patches from development builds that need to be tied to a specific version.
We've re-compiled ProFTPd 1.3.9e in AlmaLinux 8, but still the same error occurred. Simply use the TLS 1.2 workaround.
(patch file - ./custombuild/patches/proftpd_mod_sftp_keys.patch - already existed, then re-compile)
A new build with additional patch for ProFTPd 1.3.9e is released. It should resolve the TLS 1.3 problems on systems with legacy OpenSSL.
Hello guys. You have removed Domain suspension reasons in this release and especially "Custom suspension reasons and "none" are no longer accepted."
I was using custom suspension reasons to set custom suspend page for different type of clients, based on the reason name. Now it is gone. Is there some workaround, we are using external system to manage DA server via API calls. Can we use details field or something else? Thanks.
A new build is released. It makes sure PHPMyAdmin examples directory is removed, the examples can give access to the PMA login page even if public login access is disabled.
Until now, I've been using ProFTPD with SFTP support enabled through a custom build configuration file:
/usr/local/directadmin/custombuild/custom/proftpd/configure.proftpd
My question is: Can I now safely remove this custom configuration file if DirectAdmin correctly detects and uses my proftpd_sftp_port setting?
In other words, does CustomBuild now automatically compile ProFTPD with mod_sftp support when proftpd_sftp_port is configured, without requiring any custom build options?
@matkra, yes our goal is to make sure users who use ProFTPD mod_sftp would no longer need any customizations at all.
The module mod_sftp is always compiled but enabled or disabled depending on the proftpd_sftp_port option value.
@pstoilov, the reason we are going away from custom suspension reasons file is:
  • make sure suspension reasons are translatable (to other languages than English). The additional translations in custom translations file was untranslatable.
  • To avoid placing user controlled data inside the apache configuration file (the fully translated suspension reason text).
Our goal is to have a pre-defined list suspension reasons. If the list is too short - just let us know we will add more suspension reasons.
If you would like to show arbitrary message (the suspension details) in the suspension page, this would be a feature request.
