2e harddisk
snaaps
Netherlands
I have a second hardisk in my server, but if I go to # cd /mnt I dont see this hardisk.
Proberly I most format an make partitions
How do I dow this?
What Operating System are you running?
A basic check that needs to be done: Make sure your bios detects the 2nd drive, if it's not you have hardware issues to solve before moving on to formating and mounting.
os is fedora core 3
the bios detect the drive ok
Als when I installed OS he saw the second drive.
But now cant i see it
Did you format and set a mount point for it when you installed?
I haven't used Fedora Core, but I would think most linux distributions are the same. There should a parition management tool, which you can use to format the hard drive and create partitions. You should set the mount point somewhere in that process.
