Hi all...
when trying to send email (using webmail or outlook) users of the server seem to be getting this msg (copied from OE):
An unknown error has occurred. Subject 'testing', Account: 'TnS Int - Main', Server: 'mail.tns-int.com', Protocol: SMTP, Server Response: '451 Temporary local problem - please try later', Port: 25, Secure(SSL): No, Server Error: 451, Error Number: 0x800CCC6A
Now, i've read the only 1 thread here about this problem and it seem to be my case is different, there isnt seem to be a DNS problem (anyone from every where can access the server).
i've copied the last few lines recived on the mainlog file from exim:
as you can see it seems like the problem is on the server itself.
a little more info:
This server is running the latest DA, it has only been installed a week ago, in the first day or two emails sending was fine (or so it seemed
Any ideas ?
Thanks,
Tomer
2005-12-03 21:07:41 1EicjV-0007tH-14 malware acl condition: clamd: unable to connect to UNIX socket /var/run/clamav/clamd (No such file or directory)
2005-12-03 21:07:41 1EicjV-0007tH-14 H=cpe-24-29-159-132.nyc.res.rr.com (tomer) [24.29.159.132] F=<[email protected]> temporarily rejected after DATA
2005-12-03 21:07:46 1EicjZ-0007tL-UK malware acl condition: clamd: unable to connect to UNIX socket /var/run/clamav/clamd (No such file or directory)
2005-12-03 21:07:46 1EicjZ-0007tL-UK H=cpe-24-29-159-132.nyc.res.rr.com (tomer) [24.29.159.132] F=<[email protected]> temporarily rejected after DATA
2005-12-03 21:08:21 1Eick8-0007tS-OV malware acl condition: clamd: unable to connect to UNIX socket /var/run/clamav/clamd (No such file or directory)
2005-12-03 21:08:21 1Eick8-0007tS-OV H=cpe-24-29-159-132.nyc.res.rr.com (tomer) [24.29.159.132] F=<[email protected]> temporarily rejected after DATA
2005-12-03 21:08:22 1EickA-0007tT-IG malware acl condition: clamd: unable to connect to UNIX socket /var/run/clamav/clamd (No such file or directory)
2005-12-03 21:08:22 1EickA-0007tT-IG H=cpe-24-29-159-132.nyc.res.rr.com (tomer) [24.29.159.132] F=<[email protected]> temporarily rejected after DATA
a little more info:
Any ideas ?
Thanks,
Tomer
