Abnormal system load
sifro
i suddendly started receiving emails from directadmin like this one:
This is an automated message notifying you that the 5 minute load average on your system is 73.62.
This has exceeded the 10 threshold.
One Minute - 74.21
Five Minutes - 73.62
Fifteen Minutes - 71.39
top - 03:52:04 up 3 days, 8:52, 0 users, load average: 74.35, 73.66, 71.41
Tasks: 304 total, 75 running, 229 sleeping, 0 stopped, 0 zombie
Cpu(s): 72.1%us, 2.0%sy, 0.1%ni, 23.9%id, 1.2%wa, 0.4%hi, 0.4%si, 0.0%st
Mem: 3115464k total, 2840484k used, 274980k free, 197472k buffers
Swap: 5177336k total, 76k used, 5177260k free, 1702148k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
19392 apache 25 0 34096 15m 3548 R 19.6 0.5 0:10.49 /usr/sbin/httpd -k start -DSSL
19480 apache 24 0 34172 15m 3788 R 19.6 0.5 0:04.79 /usr/sbin/httpd -k start -DSSL
19481 apache 25 0 34048 14m 3436 R 19.6 0.5 0:10.49 /usr/sbin/httpd -k start -DSSL
19482 apache 25 0 34180 14m 3500 R 19.6 0.5 0:06.63 /usr/sbin/httpd -k start -DSSL
19881 apache 25 0 34048 14m 3436 R 19.6 0.5 0:10.49 /usr/sbin/httpd -k start -DSSL
20262 root 20 0 2424 1032 696 R 2.0 0.0 0:00.01 /usr/bin/top -c -b -n 1
1 root 15 0 2160 596 516 S 0.0 0.0 0:00.62 init [3]
2 root RT -5 0 0 0 S 0.0 0.0 0:00.00 [migration/0]
3 root 34 19 0 0 0 R 0.0 0.0 0:00.00 [ksoftirqd/0]
4 root RT -5 0 0 0 S 0.0 0.0 0:00.00 [watchdog/0]
5 root 10 -5 0 0 0 S 0.0 0.0 0:00.04 [events/0]
6 root 10 -5 0 0 0 S 0.0 0.0 0:00.00 [khelper]
7 root 10 -5 0 0 0 S 0.0 0.0 0:00.00 [kthread]
10 root 10 -5 0 0 0 S 0.0 0.0 0:00.37 [kblockd/0]
11 root 20 -5 0 0 0 S 0.0 0.0 0:00.00 [kacpid]
109 root 20 -5 0 0 0 S 0.0 0.0 0:00.00 [cqueue/0]
112 root 10 -5 0 0 0 S 0.0 0.0 0:00.00 [khubd]
114 root 10 -5 0 0 0 S 0.0 0.0 0:00.00 [kseriod]
179 root 15 0 0 0 0 S 0.0 0.0 0:00.00 [khungtaskd]
180 root 25 0 0 0 0 S 0.0 0.0 0:00.00 [pdflush]
181 root 15 0 0 0 0 S 0.0 0.0 0:04.77 [pdflush]
182 root 10 -5 0 0 0 S 0.0 0.0 0:01.07 [kswapd0]
183 root 20 -5 0 0 0 S 0.0 0.0 0:00.00 [aio/0]
If i go to "service monitor" i can see lots of apache PIDs, and the websites are very slow.
If i restart apache, sites get back to normal, but after around 30 minutes, there are once again a lot of spawned apache processes and an unusual high load.
Any ideas on how to solve this?
I haven't had any abnormal increase in the amount of traffic, so why did it start freaking out?
Here's the result of my "system info" page:
Processor Name QEMU Virtual CPU version (cpu64-rhel6)
Vendor ID GenuineIntel
Processor Speed (MHz) 2394.306
Total Memory 3115464 kB
Free Memory 864084 kB
Total Swap Memory 5177336 kB
Free Swap Memory 5177260 kB
System Uptime 3 Days, 14 Hours and 14 Minutes
Apache 2.2.22 Running
DirectAdmin 1.39.3 Running
Exim 4.76 Running
MySQL 5.0.67 Running
Named 9.3.6 Running
ProFTPd 1.3.3c Running
sshd Running
dovecot 2.1.1 Running
Php 5.3.10 Installed
You must be under DDoS attack. You might need to enable server-status and see what's going on there, and what page/domain is mostly requested. Then either block the account with the domain, or tune your server (configure apache and install additional software/modules).
P.S. Feel free to contact me with PM, if you need my help as a commerce service.
Thanks, with server-status i could identify the IP causing the problems. I banned him, and now everything is fine.
Hi Sifro,
Can you write down how you found the IP Address and how you banned it?
Sometimes i have the same problem.
The strange thing is, that i just recieved a new server.
There are no users on it and i already get brute force messages.
Thx for your how to.
Enable server-status in Apache config and open it in your browser, you'll all active connections and IPs.
Hi, you really should enable server-status... there are tons of annoying IPs out there, mine can't be the same of yours.
For more info, have a look at this: http://httpd.apache.org/docs/2.0/mod/mod_status.html
You just have to edit your httpd-info.cfg file in /etc/httpd/conf/extra (or something similar).
Anyway, this problem is happening again... and this time i guess it's caused by... Googlebot! It opens lots of connections and then apache doesn't close them!
Here are the outputs of some useful commands:
netstat -plan|grep :80 |awk '{print $5}' | awk -F : '{print $(NF-1)}' | sort | uniq -c | sort -n
1
1 151.37.103.129
1 151.51.45.144
1 151.66.59.146
1 151.95.20.105
1 178.198.31.93
1 188.11.48.206
1 2.196.63.135
1 31.190.74.248
1 87.21.160.98
3 159.20.194.86
4 31.26.20.157
5 66.249.66.44
5 79.31.143.176
6 151.73.52.57
6 93.46.112.207
8 2.227.18.196
8 2.38.35.29
8 31.159.152.45
8 82.91.108.210
8 95.244.88.65
9 95.250.33.93
12 88.86.172.81
15 66.249.72.88
27 95.231.5.100
netstat -a | grep 66.249 shows 20 connections from googlebot ip, 1 in ESTABILISHEd status, the others in TIME WAIT.
Apache server-status shows this:
Total Accesses: 292068
Total kBytes: 5540956
CPULoad: .0884054
Uptime: 45823
ReqPerSec: 6.37383
BytesPerSec: 123823
BytesPerReq: 19426.8
BusyWorkers: 99
IdleWorkers: 10
Scoreboard: WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWWWWWWWWWWKWWWWWCWWWWWWWWWKWWWWWWWWWWKWWW_W_CWWW__WS__K_WWK__K_S........
... and the non machine-friendly version adds hundreds of lines like this one:
22-0 8559 0/58/149 _ 1.57 3 293 0.0 2.36 3.80 66.249.66.44 www.mydomain.com GET /modules.php?op=modload&name=Kalender&file=index&Date=01/31
66.249.66.44 is googlebot's IP.
So, basically, googlebot opens connections, and my webserver doesn't closes them.... any ideas to solve this?
Well, i can't block googlebot!
It is supposed to index my websites, how are my visitors going to find me then?
If it's one project server, then create an account in Google Webmaster and set limits for requests of Google-Bots, something of this king is possible, as far as I know....... or tune your software (for this part I'm available to do the job for a price as well as some other members of the forums here).
