Adding and running domains
Itachi
Hello all,
After nearly ten years of centos5 with da, I finally upgraded to centos8. I installed da, and suprised by the new look and features. But I feel just like using iphone, first of all it added my main domain somehow not visible in anywhere but also not addable because "this domain is already..." error.
Then I added user package and new user. I use a dns server from my server company, but da keeps adding my main domains nameserver by default. and those can not be changed https://snaptube.cam/.
All domains are showing " apache is working correctly"
Well I want to learn if this is a completely different DA than the old one? Becuse I use DA for about ten years. But after 2 hours of work not a single domain is working and it gets me a little sad.
Regards
Hello all,
Regards
Do you have IPv6 enabled? If this is the case, you must link IPv6 with IPv4 in DA UI. This is just my assumption because I had the same page all over the domain saying "apache is working correctly". But after I linked my IPv6 to IPv4 and vice versa, I got it work.
There are some useful error logs in here that you can navigate, it might give a clue why you got 'apache is working correctly':
