Alternative solution for fixing named not being reloaded
Paul K
For this (http://help.directadmin.com/item.php?id=40) FAQ item, there is another solution that will fix it. For me, the solution in this FAQ did not even work.
A simple solution:
Create a dns_write_post.sh in /usr/local/directadmin/scripts/custom, put in
/etc/init.d/named reload
(Dont forget to chmod 755)
Now your named will be reloading correctly :)
I never heard of named not being reloaded... I am sure you have some other problem.
Why are they restarting it that way...
Whats wrong with:
/usr/sbin/rndc reload
You could also reload a single zone too and test for problems against only that zone.
Whats wrong with:
I haven't said my solution is the best, I just noticed that while creating domains the named server was not reloaded and therefore the domain would not resolve. This FAQ item was exactly the problem I had, but it did not have the right solution. After applying this fix, it worked so I thought sharing it might help so people.
