transmobius
- Jan 11, 2006
Trying './build all d' after an OpenSSL upgrade and I get a failure as the script gets to Apache:
gcc -c -I../../os/unix -I../../include -DLINUX=22 -DHAVE_SET_DUMPABLE -I/usr/include/gdbm -DMOD_SSL=208131 -DUSE_HSREGEX -DEAPI `../../apaci` -fpic -DSHARED_MODULE -DSSL_COMPAT -DSSL_USE_SDBM -I/usr/include -DMOD_SSL_VERSION=\"2.8.31\" ssl_util_ssl.c && mv ssl_util_ssl.o ssl_util_ssl.lo
ssl_util_ssl.c: In function `SSL_X509_isSGC':
ssl_util_ssl.c:327: error: `STACK' undeclared (first use in this function)
ssl_util_ssl.c:327: error: (Each undeclared identifier is reported only once
ssl_util_ssl.c:327: error: for each function it appears in.)
ssl_util_ssl.c:327: error: `sk' undeclared (first use in this function)
ssl_util_ssl.c:336: error: syntax error before ')' token
ssl_util_ssl.c:337: error: syntax error before ')' token
ssl_util_ssl.c:341: error: break statement not within loop or switch
ssl_util_ssl.c: At top level:
ssl_util_ssl.c:345: error: syntax error before '}' token
make[4]: *** [ssl_util_ssl.lo] Error 1
make[3]: *** [all] Error 1
make[2]: *** [subdirs] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/apache_1.3.41/src'
make[1]: *** [build-std] Error 2
make[1]: Leaving directory `/usr/local/directadmin/custombuild/apache_1.3.41'
make: *** [build] Error 2
