Apache 2.0 problem
welch
I tried out the new apache 2 with directadmin on a test box, and noticed that there is an error. When a domain is created, it is using PORT 80 but in apache 2 it changed to LISTEN 80 . Can we get a fix for this?
asap?
Changing it to Listen 80 does work?
If it does you can modify the default httpd template file that directadmin uses.
I think its in /usr/local/directadmin/data/templates
They might be a tutorial on help.directadmin.com
I just noticed a few errors with the apache 2.0 . I will try that and get back with you.
Makes me look like a tard, but i forgot to restart directadmin before adding a new domain. DON'T FORGET TO RESTART DIRECTADMIN...
:rolleyes:
:confused:
Directadmin should restart or do what it needs to automatically. Unless you changed stuff manually through the command line then nevermind this :p
