We are using Centos 6 64 Bit. I've installed the Varnish and set the ports. When i switch Apache port from 80 to 8080 it says "Apache is functioning normally" but the website is not opening. How can i fix this?
httpd.conf
Admin panel: Directadmin.
OS: Centos 6.0 64 Bit
Thanks.
httpd.conf
ServerRoot "/etc/httpd"
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 8080
Thanks.
