Apache and FTP Problem
R1Tech
we bought the new server and we update the panel directadmin but ı have 2 problem
1. server didnt show the site download for update which have it ı shoe it there
http://www.ugurcandogan.com/sorun.jpg
2. second problem is public html in ftp folder /home/kullanıcı/domains/public_htm folder links cant updated . what ıam ı doing ? ı show the picture what ı want to do it but ı cant
true way is
http://www.ugurcandogan.com/normal.jpg
folder which is underline it . sholud seen the link but it cant ??????
http://www.ugurcandogan.com/bozuk.jpg
and contect the web site with cuteftp ...picture looklike is this document
http://www.ugurcandogan.com/sorun2.jpg
Try to delete your account and create it again - something has gone completely wrong
No not normal anymore with the latest DA update. See version history.
Symlink does not exist anymore. public_html is now a folder. See version history.
There is a symlink for ugurcandogan.com in the public_html folder.
All the above refers to the public_html folder that is within /home/username
Version history tells you everything.
http://www.directadmin.com/features.php?id=855
Before updating you should always check the version history so that you know what is going to change.
http://www.directadmin.com/versions.php
Everything looks normal according to the latest DA version history.
