apache problem in debian
blueice
i have try to upgrade my debian servers to the latest versions of apache but in the php build i receive this error:
                 from /usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.                                              c:34:
/usr/local/include/zzip/zzip.h:9:10: #include nested too deeply
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `php_zi                                              p_free_dir':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:89: error: `ZZIP_DIR                                              ' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:89: error: (Each und                                              eclared identifier is reported only once
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:89: error: for each                                               function it appears in.)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:89: error: `z_dir' u                                              ndeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:89: error: syntax er                                              ror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `php_zi                                              p_free_entry':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:98: error: `entry' u                                              ndeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:98: error: syntax er                                              ror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `zif_zi                                              p_open':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:133: error: `ZZIP_DI                                              R' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:133: error: `archive                                              _p' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `zif_zi                                              p_read':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:164: error: `ZZIP_DI                                              R' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:164: error: `archive                                              _p' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:165: error: `entry'                                               undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:171: error: syntax e                                              rror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `zif_zi                                              p_close':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:190: error: `ZZIP_DI                                              R' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:190: error: `archive                                              _p' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:195: error: syntax e                                              rror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `php_zz                                              ip_get_entry':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:206: error: `entry'                                               undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:211: error: syntax e                                              rror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `zif_zi                                              p_entry_open':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:269: error: `ZZIP_DI                                              R' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:269: error: `archive                                              _p' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:270: error: `entry'                                               undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:277: error: syntax e                                              rror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:278: error: syntax e                                              rror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:280: error: `O_RDONL                                              Y' undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `zif_zi                                              p_entry_read':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:291: error: `entry'                                               undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:299: error: syntax e                                              rror before ')' token
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c: In function `zif_zi                                              p_entry_close':
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:317: error: `entry'                                               undeclared (first use in this function)
/usr/local/directadmin/customapache/php-4.4.2/ext/zip/zip.c:322: error: syntax e                                              rror before ')' token
make: *** [ext/zip/zip.lo] Error 1
I have this error in 6 debian servers.
Can everyone check if the latest build script for apache work in other debian servers?
Before you built php in /usr/local/directadmin/customapache did you run a ./build clean first before building php?
sure i have do ./build clean and ./build update before.
You have compile the latest build script in debian and work fine?
