Apache problem
ircman
The Hague, Netherlands
The strangest thing just happend. Apache had 53 running processes and did not respond to any query's.
I had to restart apache to fix this.
Is this a known problem ? or did i just found a bug :)
Cedric
check your /var/log/httpd/error_log
Also, you depending on how many domains you have (~700+), you may need to edit the virtual_host templates and comment out the "ErrorLog" lines becuase the kernel may have reached the file descriptor limit.
