Hi everybody.
I'm really having some trouble with an unstable server.
Last week we had some mysql problems, now we have some urgent and large problems with Apache, php and so on.
The problem started to day with trying to compile php, gd and freetype.
That didn't work at all, (it screamed something about curl, perl and so on.)
and after restarting apache some problems came visible.
I'm up for about a few hours now, (18,5h now) and still not having any solution.
Now i do have an other and more urgent problem:
Apache is running now, nut cannot be started, stopped or restarted (and so also reloaded) from the control panel.
It loads the page, and says: "The process is stopped".
From that moment on, it cannot be started from the control panel.
Now i'm so far that i can start it from the command prompt, with httpd killall, followd by http start.
( again, /etc/local/etc/rc.d/httpd start will not work)
So my first question, how to get and solve this problem????
Second question, i did start this day for about 19 hours ago, with the intention of getting this server to work with freetype.
i'd stil like this server to work with freetype, because there are severral customers on this server wo'd like to use this.
I do believe there is an solution for bot of the problems, but now i'd really need some help or advice how to get this..
(and most important to get apache stable, so thet i can get some sleep.)
(i'm also discussing this with da support, but wit no succes so far, but still a big hand for da support, for reacting as soon as they did.
