hi all!
When I try to reload apache from DA , apache crashes
with following errors:
Dec 1 17:04:28 server1 /kernel: pid 910 (httpd), uid 0: exited on signal 11 (core dumped)
Dec 1 17:05:14 server1 /kernel: pid 8289 (httpd), uid 0: exited on signal 11 (core dumped)
and here are errors from error_log (apache):
[Fri Dec 2 00:01:04 2005] [info] (2)No such file or directory: make_sock: for port 443, setsockopt: (SO_ACCEPTFILTER)
[Fri Dec 2 00:01:04 2005] [info] (2)No such file or directory: make_sock: for port 80, setsockopt: (SO_ACCEPTFILTER)
[Fri Dec 2 00:01:04 2005] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Fri Dec 2 00:01:04 2005] [notice] Apache configured -- resuming normal operations
[Fri Dec 2 00:01:04 2005] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Dec 2 00:01:04 2005] [info] Server built: Oct 24 2005 21:07:01
[Fri Dec 2 00:01:04 2005] [notice] Accept mutex: flock (Default: flock)
[Fri Dec 2 00:01:04 2005] [crit] (48)Address already in use: make_sock: could not bind to port 443
[Fri Dec 2 00:30:00 2005] [notice] SIGHUP received. Attempting to restart
[Fri Dec 2 00:30:09 2005] [info] (2)No such file or directory: make_sock: for port 443, setsockopt: (SO_ACCEPTFILTER)
[Fri Dec 2 00:30:09 2005] [info] (2)No such file or directory: make_sock: for port 80, setsockopt: (SO_ACCEPTFILTER)
[Fri Dec 2 00:30:09 2005] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Fri Dec 2 00:30:09 2005] [notice] Apache configured -- resuming normal operations
[Fri Dec 2 00:30:09 2005] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Dec 2 00:30:09 2005] [info] Server built: Oct 24 2005 21:07:01
[Fri Dec 2 00:30:09 2005] [notice] Accept mutex: flock (Default: flock)
[Fri Dec 2 00:31:00 2005] [notice] caught SIGTERM, shutting down
[Fri Dec 2 00:31:03 2005] [info] (2)No such file or directory: make_sock: for port 443, setsockopt: (SO_ACCEPTFILTER)
[Fri Dec 2 00:31:03 2005] [info] (2)No such file or directory: make_sock: for port 80, setsockopt: (SO_ACCEPTFILTER)
[Fri Dec 2 00:31:03 2005] [notice] Apache configured -- resuming normal operations
[Fri Dec 2 00:31:03 2005] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Dec 2 00:31:03 2005] [info] Server built: Oct 24 2005 21:07:01
[Fri Dec 2 00:31:03 2005] [notice] Accept mutex: flock (Default: flock)
[Fri Dec 2 01:15:32 2005] [info] [client 83.99.252.56] read request line timed out
[Fri Dec 2 02:12:04 2005] [info] [client 83.99.252.56] read request line timed out
