Apache won't start anymore! Please help!
majglow
Oregon
I was going to update my PHP and did the following:
Delete everythng in "/usr/local/directadmin/customapache" except "build"
./build clean
./build php y
Everything went smooth, then I restarted apache, but it won't load. I get no errors in my error log except the following:
[Thu Jan 19 00:25:11 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:26:01 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:26:11 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:27:01 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:27:11 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:27:33 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:28:01 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:28:11 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:29:01 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:29:11 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 00:30:24 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
and a lot more if it....
I'm running on FreeBSD. Please, somebody help.
Deleting everything is unnecessary, and eliminates your ability to downgrade.
You can simply delete configure.apache_ssl, but since that might have custom changes we don't even do that. We move it somewhere safe.
Then we run:
# ./build update
Then we compare the new configure.apache_ssl with the old to see if we have to make any modificaitons.
Then we do:
# ./build clean
./build all d
./build zend
Then we check to make sure there's a link from libgdbm.so to the proper library:
# cd /usr/lib
# ls -al libgdbm.so
if not found:
# cd /usr/lib
# ln -s libgdbm.so.2.2.0 libgdbm.so ??? (2.0.0)
then we verify:
# ls -al libgdbm.so*
and finally restart httpd.
Adding a note to point out that I don't mean to imply you have any ability to downgrade.
I just tried to downgrade PHP and completely broke customapache.
So don't take my statement above as a guarantee you can downgrade even if you keep the files.
