i had deleted the /etc/apache2/ folder by mistake and hence i uninstalled apache2 package and reinstalled it.. (apache2.2-common, apache2, apache2-utils, and many libapache2-mod packages)...
this is the error i am getting when i try to start apache2 with the following command..
$> /etc/init.d/apache2 start
> Forcing reload of web server (apache2)...Syntax error on line 141 of /etc/apache2/apache2.conf:
Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
failed!
I am sure that mod_access module for apache is missing and not enabled along with other needed apache modules..
How do i install them separately rather than building from apache2.2 source code..??
Please Help...
failed!
Please Help...
