Solved Appache not running (AH00526)
Davey
NL
Apache is not running on our webserver.
AH00526: Syntax error on line 31 of /etc/httpd/conf/extra/httpd-vhosts.conf:
The address or port is invalid
Our httpd-vhosts.conf looks likes this:
<VirtualHost [178.18.82.4.bak 178.18.82.4 2a02:348:55:5204:0:0:0:1]:80>
ServerAdmin webmaster@localhost
UserDir public_html
DocumentRoot /var/www/html
ServerName localhost
ScriptAlias /cgi-bin/ /var/www/cgi-bin/
CustomLog /var/log/httpd/homedir.log homedir
CustomLog /var/log/httpd/access_log combined
ErrorLog /var/log/httpd/error_log
<IfModule !mod_ruid2.c>
SuexecUserGroup webapps webapps
</IfModule>
</VirtualHost>
<VirtualHost [178.18.82.4.bak 178.18.82.4 2a02:348:55:5204:0:0:0:1]:443>
UserDir public_html
SSLEngine on
SSLCertificateFile /etc/httpd/conf/ssl.crt/server.crt.combined
SSLCertificateKeyFile /etc/httpd/conf/ssl.key/server.key
#SSLCACertificateFile /etc/httpd/conf/ssl.crt/server.ca
</IfModule>
</VirtualHost>
./build apache d gives the same error.
./build rewrite_confs gives:
Checking to ensure /etc/httpd/conf/ssl.crt/server.ca is set.
Using [178.18.82.4.bak
178.18.82.4
2a02:348:55:5204:0:0:0:1] for your server IP
./build: line 15515: [: too many arguments
Any ideas?
Remove it.
change:
to
<VirtualHost [178.18.82.4 2a02:348:55:5204:0:0:0:1]:443>
where present, and restart apache. See if it still throws errors or not.
Also check /usr/local/directadmin/custombuild/custom/ap2/extra directory if a httpd-vhosts.conf (or any other file) is in there too.
removing the 178.18.82.4.bak (2x) does not help.
/usr/local/directadmin/custombuild/custom/ap2/extra/httpd-vhosts.conf
<VirtualHost |IP|:|PORT_80||LINKEDIP|>
UserDir public_html
</IfModule>
</VirtualHost>
<VirtualHost |IP|:|PORT_443||LINKEDIPSSL|>
UserDir public_html
SSLEngine on
</IfModule>
</VirtualHost>
Thanks for the assistance!
Exactly how did it not help? If apache still not starts, you should get another error notice now.
Try this via SSH as root:
after that, the httpd-vhosts.conf in the normal directory should look the same (but with ip's) as in the /custom/ap2/extra directory.
If you start apache again after that, does it work? If not, what is the exact error notice?
If it does not start, also do this command and check the output:
apachectl configtest
Same error.
/sbin/service httpd start 2>&1
Gives:
[root@e30 custombuild]# ./build rewrite_confs
178.18.82.4
Gracefully shutting down php-fpm80: . done
Starting php-fpm80: [14-Jan-2022 19:25:04] NOTICE: PHP message: PHP Warning: PH P Startup: Unable to load dynamic library 'redis.so' (tried: /usr/local/php80/li b/php/extensions/no-debug-non-zts-20200930/redis.so (/usr/local/php80/lib/php/ex tensions/no-debug-non-zts-20200930/redis.so: cannot open shared object file: No such file or directory), /usr/local/php80/lib/php/extensions/no-debug-non-zts-20 200930/redis.so.so (/usr/local/php80/lib/php/extensions/no-debug-non-zts-2020093 0/redis.so.so: cannot open shared object file: No such file or directory)) in Un known on line 0
done
Restarting apache.
I think that is caused by that custom vhost. Probably used to get your ipv6 in there. But I'm not into ipv6 so I have to let go for that part.
Like active8 said, same.bak file and seems only the custom config can create something like that.
Do not need the ipv6, looking to remove it from de vhosts.
After a ./build rewrite_confs the .bak is back.
If you don't need it, then why the custom vhost? Try this.
Move the /usr/local/directadmin/custom/ap2/extra/httpd-vhost.conf to some place else.
Check if there is no other content in the /custom directory and beneath (if yes mention it first)
Then run the rewrite_confs again and see if that .bak is removed. My feeling says everything will be working again then, but I'm not sure anymore.
ok look like ips has some bug
what about in
/usr/local/directadmin/data/admin/ip.list
there are any something like .bak ? if have try remove it on that line and restart DA
.bak indeed. Removed it. Did a DA restart, same issue.
Using [178.18.82.4
/usr/local/directadmin/custombuild/build: line 15515: [: /usr/local/directadmin/data/admin/ips/[178.18.82.4: binary operator expected
Gracefully shutting down php-fpm74: . done
Starting php-fpm74: done
Restarting apache.
and what about that ipv6 ? did you use it ?
maybe it could remove that too. right ?
