AlmaLinux-9.1-x86_64-minimal.iso
With AlmaLinux-9.1, directadmin cannot be installed
help help !!!!!!!
			Would you like the default settings of apache and php 8.1 as php-fpm? (yes/no, default: yes):no
Please select webserver you would like to use (apache/nginx/nginx_apache/litespeed/openlitespeed, default: apache):nginx
Please select MySQL database server you would like to use (mysql/mariadb/no, default: mariadb):mysql
Please select mysql version you would like to use (8.0, default: 8.0):8.0
Please select FTP server you would like to use (proftpd/pureftpd/no, pureftpd):
Please select default PHP version you would like to use (5.3/5.4/5.5/5.6/7.0/7.1/7.2/7.3/7.4/8.0/8.1/8.2, default: 8.1):7.4
Please select default PHP mode you would like to use (php-fpm/fastcgi/suphp/lsphp/mod_php, default: php-fpm):
Would you like to have a second instance of PHP installed? (yes/no, default: no):
Please select if you would like to use ionCube (yes/no, default: no):
Please select if you would like to use opCache (yes/no, default: no):
Please select if you would like to use Zend Guard Loader (yes/no, default: no):
Please select if you would like CustomBuild to manage Exim installation (yes/no, default: yes):
Please select if you would like CustomBuild to manage Dovecot installation (yes/no, default: yes):
Please select if you would like CustomBuild to manage phpMyAdmin installation (yes/no, default: yes):
Please select if you would like CustomBuild to manage SquirrelMail installation (yes/no, default: no):
Please select if you would like CustomBuild to manage RoundCube installation (yes/no, default: yes):
I'm from China.[root@localhost ~]# tail -f /usr/local/directadmin/custombuild/install.txt
Changed csf option from no to yes
-=O=-# # # #
php 5.x, 7.x and 8.0 cannot compile against openssl 3.0 or higher. Try php 8.1 or higher.
^[a^[a
help help !!!!!!!
