autoresponder failed for domains which using smart_route
tsimtung
We have tried to setup autoresponder, but it is failed for the sender domains which using smart_route:
for example, for gmail.com, I will smart_route it to another ip to send, and then the auto respond cannot be sent.
then I tried to set gmail not using smart_route, then it has this log:
[root@tal55 named]# tail -100000 /var/log/exim/mainlog|grep 1t68sr-001U5Y-03
2024-10-30 21:37:13 1t68sr-001U5Y-03 <= <> R=1t68sq-001U5R-P6 U=mail P=local S=674 T="Autoreply: \"Re: test aaaa\"" from <> for [email protected]
2024-10-30 21:37:13 cwd=/var/spool/exim 3 args: /usr/sbin/exim -Mc 1t68sr-001U5Y-03
2024-10-30 21:39:25 1t68sr-001U5Y-03 H=gmail-smtp-in.l.google.com [2404:6800:4008:c02::1b] Connection timed out
2024-10-30 21:39:28 1t68sr-001U5Y-03 ** [email protected] F=<> R=lookuphost T=remote_smtp H=gmail-smtp-in.l.google.com [74.125.23.27] X=TLS1.3:TLS_AES_256_GCM_SHA384:256 CV=yes: SMTP error from remote mail server after end of data: 550-5.7.26 Your email has been blocked because the sender is unauthenticated.\n550-5.7.26 Gmail requires all senders to authenticate with either SPF or DKIM.\n550-5.7.26\n550-5.7.26 Authentication results:\n550-5.7.26 DKIM = did not pass\n550-5.7.26 SPF [] with ip: [103.252.116.2x3] = did not pass\n550-5.7.26\n550-5.7.26 For instructions on setting up authentication, go to\n550 5.7.26 https://support.google.com/mail/answer/81126#authentication 98e67ed59e1d1-2e92fc054cbsi1659002a91.166 - gsmtp
2024-10-30 21:39:28 1t68sr-001U5Y-03 Frozen (delivery error message)
for normal email, the sender domain can send email to gmail successfully, but autoresponder failed.
i setup spf correctly, not no set dkim
what is this problem?
Thanks,
Stanley
