ziggyz27
- May 1, 2008
I spent 24 hours looking for this help, picked up bits n pieces here and there. So here is all that I wanted and the problems that were resolved with my AWSTATS setup.
Problems:
1. Manual Upgrade Stats_control plugin, awstats from version 6.4 to 6.9(current)
2. Fix permissions error I get consistently to fix following:
3. Process OLD logs again covering all history
My Server:
6.1-RELEASE FreeBSD
DA version 1.33.6
1. MANUAL Upgrade AWSTATS to 6.9
Goto Sourceforge and download latest version, I used following mirror:
http://nchc.dl.sourceforge.net/sourceforge/awstats/awstats-6.9.tar.gz
cd /usr/local/directadmin/plugins/Stats_Control/
wget http://nchc.dl.sourceforge.net/sourceforge/awstats/awstats-6.9.tar.gz
tar -zxvf awstats-6.9.tar.gz
#moved existing awstats to another directory
mv awstats awstats-6.4
#relinked the awstats to latest version to keep things running
ln -s awstats-6.9/ awstats
#give it proper users:group ownership
chown -R diradmin:wheel awstats-6.9/
cd awstats-6.9/
#moved all files in wwwroot/ directory to base directory of new awstats
mv wwwroot/* .
NOTE: 6.9 version could not find my geoip module in my perl. Just added geoip from ports as follows:
cd /usr/ports/net/p5-Geo-IP/ && make install clean
NOTE: It required me to deinstall my older version so:
cd ../net/geoip/
make deinstall
cd ../net/p5-Geo-IP/
make reinstall
==DONE===========================================
Thats it you have upgraded!
Well I still had that error to fix. After much research I did following:
cd /var/log/httpd/
#just the directory
chown apache:apache domains/
# NOTE this is not recommended but until I have this figured out this works
# it allows script to read all logs
chmod 777 domains/
#NOTE: All log files in domains/ are with w+x permissions and owned by root:nobody
-rwx--x--x 1 root nobody
THIS ALLOWED MY AWSTATS ERROR TO GO AWAY! I WILL UPDATE AS SOON AS I HAVE FIGURED OUT CORRECT USER:GROUP OWNERSHIP AND FILE PERMISSIONS
=====DONE=================================================
#My domains logs are in following path:
#/home/user/domains/userdomain/logs/
# it has all my customer domain logs in tgz files.
-rw-r--r-- 1 root wheel 374812 Aug 1 2007 2007-08-01.tar.gz
-rw-r--r-- 1 root wheel 390497 Sep 1 2007 2007-09-01.tar.gz
-rw-r--r-- 1 root wheel 339935 Oct 1 2007 2007-10-01.tar.gz
-rw-r--r-- 1 root wheel 422753 Nov 1 2007 2007-11-01.tar.gz
NOTE: You may have some tgz files like these:
-rw-r--r-- 1 root wheel 4402 Jul 1 2008 2008-07-01(10).tar.gz
-rw-r--r-- 1 root wheel 1131 Jul 1 2008 2008-07-01(11).tar.gz
-rw-r--r-- 1 root wheel 1664 Jul 1 2008 2008-07-01(12).tar.gz
-rw-r--r-- 1 root wheel 1534 Jul 1 2008 2008-07-01(13).tar.gz
IGNORE all files with () in their names. Main files we need to use are without () brackets in their names.
#My awstats stats files are generated in
#/home/user/domains/userdomain/stats/
cd /home/user/domains/userdomain/stats/
#I created a temp/ folder in stats/
mkdir temp/
#move all previous files to temp for safe keeping
mv *com* temp/.
#back to logs directory
touch awstats_list_files
touch xtall
chmod 777 xtall
vi xtall
### COPY Following Script ####
### I wrote it myself not very cool but does the job ###
### Pay attention to <changetouserdomain> and replace it ###
### This script will process each of your tgz files one by one###
Now prepare the "awstats_list_files"
List your directory and copy files block like as follows making sure there is one file name per line:
vi awstats_list_files
2007-08-01.tar.gz
2007-09-01.tar.gz
2007-10-01.tar.gz
2007-11-01.tar.gz
2007-12-01.tar.gz
2008-01-01.tar.gz
2008-02-01.tar.gz
## save file ##
#Thats it...RUN:
./xtall
#run above script and keep watching... it will process all old logs
NOTE: You may have to customize all of above script based on your server setup.
Problems:
Error: Couldn't open server log file "/var/log/httpd/domains/userdomain.com.log" permission denied
My Server:
6.1-RELEASE FreeBSD
DA version 1.33.6
cd awstats-6.9/
mv wwwroot/* .
cd ../net/geoip/
make deinstall
make reinstall
cd /var/log/httpd/
#just the directory
chmod 777 domains/
mkdir temp/
mv *com* temp/.
touch xtall
chmod 777 xtall
vi xtall
count=1
for file in `cat awstats_list_files`
do
echo "Processing File no#"$count "->" $file
tar -zxvf $file -C temp/
/usr/local/directadmin/plugins/Stats_Control/awstats/cgi-bin/awstats.pl -update config=<changetouserdomain>.com -LogFile="/usr/local/directadmin/plugins/Stats_Control/awstats/tools/logresolvemerge.pl temp/<changetouserdomain>.com.*log |"
echo "Logs processed, deleting logs"
rm -rf temp/*.log
echo "files deleted"
echo " "
count=`expr $count + 1`
done
2007-08-01.tar.gz
2007-09-01.tar.gz
2007-10-01.tar.gz
2007-11-01.tar.gz
2007-12-01.tar.gz
2008-01-01.tar.gz
2008-02-01.tar.gz
## save file ##
#Thats it...RUN:
./xtall
