Awstats plugin problem
Daskew
Clitheroe, UK
When trying to activate awstats for a domain I get the following error:
Checking if there is already something installed..
AwStats Directory already exists on domain
Checking if awstats files are available....
Checking for AwStats itself
Awstats already exists.
So I will delete it...Deleted!
Going to install the awstats.pl
(Re-)Activating CGI for dir
Ok .htaccess already exists let's delete it..Deleted!
Doing an extra permission setting through shell..+(Re-)Setting permissions
Doing an extra permission setting through shell..Done
Now (re-)creating your configuration file.
Warning: fopen(/etc/awstats/awstats.daveaskew.com.conf): failed to open stream: Permission denied in /usr/local/directadmin/plugins/awstats/user/index.html on line 124 Warning: fwrite(): supplied argument is not a valid stream resource in /usr/local/directadmin/plugins/awstats/user/index.html on line 132 Warning: fclose(): supplied argument is not a valid stream resource in /usr/local/directadmin/plugins/awstats/user/index.html on line 133
Default password protection set.
Userid: admin
Password: default
It is EXTREMELY recommended that you use the Tune AwStats and modify the default values immediately!
Config file has been created and your statistics are now setup!
You can now view the statistics for your domain at: domain.com/awstats/
Ive seen others have the same problem but not seen a solution yet, can anyone help please?
