raqdedicados
HI there
I just installed a clean server with default options, after this installed the awstats.sh, put them onto cron but now i can't see nothing also i try to search
awstats_configure.pl but it does not exist on the system
i got his message
Error: Couldn't open config file "awstats.selnet.com.ar.conf" nor "awstats.conf" after searching in path ".,/etc/awstats,/usr/local/etc/awstats,/etc,/etc/opt/awstats": No such file or directory
- Did you use the correct URL ?
Example: http://localhost/awstats/awstats.pl?config=mysite
Example: http://127.0.0.1/cgi-bin/awstats.pl?config=mysite
- Did you create your config file 'awstats.selnet.com.ar.conf' ?
If not, you can run "awstats_configure.pl" from command line, or create it manually.
Check config file, permissions and AWStats documentation (in 'docs' directory).
Can someone guide us a little on how to fix it please ?
Thanks !!
i got his message
Thanks !!
