Hi there,
I wasn't sure where to post this, but I found this thread on remote back-up.
In my control panel I marked the remote back-up option and selecte scp as the method. I entered valid user/pass combination on a remote server.
To make sure the key was already in the known_hosts file I manually made an SSH connection to this server to accept the key.
OK, now the problem is that it does not work. No remote back-up but also no errors is de /directadmin/error.log.
I can't find what it tries to do because the /directadmin/scripts/sysbk.sh does not seem to be the script running the systemback-up...
So questions to any who have an answer:
- which script actually runs the back-up (so I can see what it does)
- in which log would remote back-up errors appear?
- does DA run the backup as user dadmin, or root, or some other user? Maybe I need to log in as THAT user for the first time to accept the right SSH-key. Where would the dadmin user's known_hosts be stored, since it doesn't have a homedir...??
Thanks, once again, for your input!
Harro
<edit> dadmin DOES have a homedir... let's run the back-up now that I added the remote key manually as user dadmin! </edit>
