backups problems
rskyline
I'm having trouble with backups, the current users on this server were migrated from another DA server backup, now when I try to setup a programmed backup from the DA Admin panel I get some errors, it seems that it's trying to store de backed files on the wrong folders.
This is the backup setup on the DA Admin panel:
*target IP was removed
This are the errors I get when the backup jobs completes:
View attachment islademaipo1.txt
View attachment islademaipo2.txt
I would appreciate if anyone can help to solve this
Thanks,
Try a manual ftp command (through shell) to the backup server usoing the same settings for username, password, and root directory, and see what you get.
Instead of the / as root directory maybe try the full path to the username's home directory on the backup server, without a / at the end.
That's what works for me.
