A little background info before I go into the problem/question I recently Installed WHMCS Billing and management system to control clients on a new server. Before that I had AWBS billing and management system. I also updated Directadmin to the newest version 1.31.2 at about the same time so im not sure if its an update problem or the previous software so im giving some extra info just in case. I will move one of my hosted domains to a manually created directadmin account to see if the problem still exists. I just thought I would post and see if anyone could help me out in the mean time.
First Problem - Users are created correctly with the correct package that was set up, but their bandwidth is not tallied at all. The disk usage data is correctly tallied though.
I get the following error message when you try to view bandwidth data
Error while breaking down the bandwidth.tally file
Details
Unable to read ./data/users/(user name - edited out)/bandwidth.tally : No such file or directory
I checked the users data directory and sure enough there is no bandwidth.tally or bandwidth.tally.cache
It has been over 5 days since the accounts were created and the bandwidth is set to tally every night at midnight
My other accounts which I created Directly within Directadmin have a bandwidth tally file and work perfectly. This was pre-directadmin update version 1.31.2 when I manually created the accounts.
Second Question - Shared IP
how do I get new sign ups to use the ip I designated for Shared use?
there is no option to set the shared ip in the reseller packages that I could find. I can manually set ip usage per account if I edit them directly, but that would be time consuming.
I did set the ip to shared using the ip management function under admin.
when a new account is created it defaults to the main server ip for some reason instead of the designated shared ip address.
Any info or help regarding the above issues would be greatly appreciated and thanks in advance.
Details
