I'm about to re-install directadmin on my server.
What is the most stable OS to use directadmin with?
The server, R300:
Quad Core Intel® Xeon® X3360, 2.83GHz, 2x6MB Cache, 1333MHz FSB
2GB Memory, DDR2, 800MHz (2x1GB Dual Ranked DIMMs)
SAS 6iR internal RAID Controller, PCI-Express
C4 - Add-in SAS6iR (SATA/SAS Controller) - RAID 1
2 x 250GB SATA (7,200rpm) 3.5inch Hard Drive
Broadcom® NetXtreme 5722 Single Port Gigabit Ethernet NIC, PCIe
- The system should preferably run 64bit and should use all 4 cores. (In the current setup it only uses 2)
- The OS must be very stable (never reboot, if possible).
- The OS must be secure. considering the 20$ offer a month from webbycart to secure it further.
Also it should be possible to run apache 2.2 and PHP with APC.
There are so many good choises out there:
Debian
FreeBSD
Ubuntu
CentOs
Fedora
etc..
What should i pick for a smooth running directadmin?
Throw your suggestions and or preferences please
The server, R300:
Debian
FreeBSD
Ubuntu
CentOs
Fedora
etc..
