I'm running DA on FreeBSD 7.2 64-bit and everything works very well.
When trying to install either WHMCS or ClientExec i'm running in to some problems.
When having either of them installed, everything works well when browsing to the admin panel via the servers ip-adress... but not via the domain name.
To clearify:
http://mydomain.tld/whmcs/ - Not working, just a blank white page
http://ip-adress/whmcs/ - Works just fine
I can open images etc that is located in the "whmcs" folder using the domain name though. So i don't think the domain is pointing towards the wrong folder on the server.
I've been in touch with the support on both whmcs and clientexec... and the only thing they can come up with is migrating back from PHP 5.2.10 to 5.2.9
I don't think that will solve the problem... since everything works fine browsing the files on the server ip.
Any thougts on what i should try next? I'm going nuts here...
Regards
FARFAR
To clearify:
Regards
FARFAR
