propcgamer
- Dec 27, 2005
So I was looking to upgrade from exim 4.72->4.73
After doing, ./build update
when I do ./build exim
It simply outputs the commands you can use with custombuild, instead of building exim.
When I check the versions.txt, it has the exim 4.73 md5.
When I check options, it shows exim is set to yes.
Did this get disabled for some reason?
