Hello I am using a fresh installation of DA and enabled CageFS, I ran the df -h command at the user level. It shows only /dev/sda1 and two tmpfs file systems. I created additional users, and CageFS is enabled for all of them. However, when I checked the login details in the passwd file, none of the new users are showing up. When I ran the cagefsctl --sanity-check, it showed the following message:
'Check CageFS virt.mp files syntax: SKIPPED: No virt.mp files found.' All other checks are OK
Anyone know how can I implement the cagefs properly.
