CGI-BIN in any dir not work
SeFlow
hi,
i search a lot in this forum but i still having cgi issue.
i want run one cgi script in a /home/admin/public_html/web/ directory, but i continue to see "500 internal ....." . Script work well, because if i insert it in cgi-bin default dir i see it without problem. In some thread i see to create .htaccess file and insert in it this:
Options +ExecCGI
AddHandler cgi-script .cgi .pl
but nothing change, i try to add it in httpd.conf but same thing.
My error is:
Premature end of script headers:
Regards, Matteo
Check Apache error log for the hints and post the relevant lines here.
Most common problems:
- user id or group id of the script doesn't match user id / group id for the domain
- permissions of the directory and the script itself
hi,
these are my logs when i try to start script fro browser:
Premature end of script headers: /home/admin/domains/seflow.net/public_html/helpdesk/rtg/web/rtgplot.cgi
i try to set all in 777 (just for made a test), and as user:group: admin:apache and admin:admin, but still same log.
Regards
That's the wrong log file I guess.
Try
tail  /var/log/httpd/suexec_log
You have to make sure that the whole path helpdesk/rtg/web/rtgplot.cgi is owned by user: admin, group admin, all the dircetories in this path have at least executable permission and the script is 755.
i tryed using 777 and during read in other forum i discovered that apache refuse it, infact i keep script and dir ay 755 (as you sayd) and now work well.
Thanks for your help.
