Checking Quota Problems.....
joeiska
It's been almost an hour, and my "Putty SHH" does not show any activity and stuck on the following line "Checking Quotas ...":
Anyone have any idea, how long should the install be? (My Box is 320 Gigs with RAID 1)
Could anyone know what's going on here?
DirectAdmin will now be installed on: Enterprise 5.2
Is this correct? (must match license) (y,n) : y
You now have 2 options for your apache/php setup.
1: customapache: older software. Includes Apache 1.3, php 4 and frontpage.
2: custombuild 1.1:  newer software (recommended). Includes any Apache version,        php 4, 5, or both in cli and/or suphp. Frontpage not available.
                 Post any issues with custombuild to the forum: http://www.direc        tadmin.com/forum/forumdisplay.php?f=61
Enter your choice (1 or 2): 2
You have chosen custombuild 1.1.
Would you like the default settings of apache 2.2 and php 5 cli? (y/n): n
You have chosen to customize the custombuild options.  Please wait while options        configurator is downloaded...
--14:49:04--  http://files.directadmin.com/services/custombuild/options-1.1
Resolving files.directadmin.com... 72.35.85.222
Connecting to files.directadmin.com|72.35.85.222|:80... connected.
Length: 11385 (11K) [text/plain]
Saving to: `/usr/local/directadmin/custombuild/options'
100%[=======================================>] 11,385      2.65K/s   in 4.2s
14:49:12 (2.65 KB/s) - `/usr/local/directadmin/custombuild/options' saved [11385        /11385]
Do you want to have PHP4 or PHP5 as default? (4/5): 5
Do you want to have PHP5? (yes/no): yes
Do you want to have PHP5 as CLI or CGI? (cli/cgi): cgi
Do you want to have PHP4? (yes/no): no
Do you want to have the php.ini (PHP configuration file) rewritten? (yes/no): ye        s
For the next question, the usual file is the dist (distribution) version.What ty        pe of php.ini (PHP configuration file) do you want to have? (dist/recommended):        recommended
Do you want to have Zend Optimizer? (yes/no): yes
Do you want to be able to update/instal MySQL using CustomBuild? (yes/no): yes
Which version of MySQL do you want to have? (4.1/5.0: 5.0
Do you want CustomBuild to backup MySQL databases before the update? (yes/no): y        es
Which version of Apache do you want to have? (1.3/2.0/2.2): 2.2
Do you want to be able to install/update phpMyAdmin using CustomBuild? (yes/no):        yes
Do you want to be able to install/update Atmail webmail using CustomBuild? (yes/        no): yes
Do you want to be able to install/update SquirrelMail webmail using CustomBuild?        (yes/no): no
Do you want to be able to install/update RoundCube webmail using CustomBuild? (y        es/no): yes
Do you want to be able to install/update UebiMiau webmail using CustomBuild? (ye        s/no): no
Do you want to install PHP mail() header patch together with PHP? (yes/no): yes
Do you want to install Dovecot? (yes/no): yes
Do you want to be able to update Exim configuration file (exim.conf) using Custo        mBuild? (yes/no): yes
Do you want to be able to install/update ProFTPD using CustomBuild? (yes/no): ye        s
Do you want CustomBuild to install Jailed shell (beta)? (yes/no): yes
Do you want CustomBuild to download versions.txt every time? (yes/no): yes
Do you want to enable bolded text? (yes/no): yes
Do you want to clean everything (run './build clean' every time) running CustomB        uild? (yes/no): yes
Which fileserver do you want to use (1 is located in USA, 2 - Europe)? (1/2): 1
Options.conf has been installed successfully
beginning pre-checks, please wait...
--14:51:53--  http://files.directadmin.com/services/es_5.0/files.sh
Length: 851 [application/x-sh]
Saving to: `/usr/local/directadmin/scripts/files.sh'
100%[=======================================>] 851         --.-K/s   in 0s
14:51:55 (106 MB/s) - `/usr/local/directadmin/scripts/files.sh' saved [851/851]
adding gd ...
*** the value for gd is empty.  It needs to be added manually ***
--14:51:55--  http://www.directadmin.com/named
Resolving www.directadmin.com... 66.51.122.131
Connecting to www.directadmin.com|66.51.122.131|:80... connected.
Length: 2472 (2.4K) [text/plain]
Saving to: `/etc/init.d/named'
100%[=======================================>] 2,472       --.-K/s   in 0.001s
14:51:57 (2.91 MB/s) - `/etc/init.d/named' saved [2472/2472]
/usr/sbin/setenforce: SELinux is disabled
--14:52:01--  https://www.directadmin.com/cgi-bin/daupdate?uid=16348&lid=46827
Connecting to www.directadmin.com|66.51.122.131|:443... connected.
Length: 3324429 (3.2M) [application/x-gzip]
Saving to: `/usr/local/directadmin/update.tar.gz'
100%[========================================================================================================================================>] 3,324,429   9.57K/s   in 94s
14:53:38 (34.7 KB/s) - `/usr/local/directadmin/update.tar.gz' saved [3324429/3324429]
Cannot find /etc/sysconfig/rhn/up2date... up2date may break things.
All Checks have passed, continuing with install...
Setting hostname to `host.info24jam.com'
mkdir: cannot create directory `/etc/virtual/usage': File exists
Checking quotas...
We encountered the same thing on just a single 250GB drive.
I took about an hour but it finally finished and everything was ok.
I would guess with your size drive and raid it may take quite awhile.
