ClamAV & Exim & FreeBSD 6.0 mime problem
IT_Architect
I installed according to the instructions at http://www.directadmin.com/forum/showthread.php?threadid=11593. However, there is a problem in that all emails are blocked if I uncomment:
#acl_smtp_mime = check_mime. The question is why, and how well does it filter for viruses if this is not working?
This is what the exim.conf file contains. I commented the exim.conf with ClarmAV wherever I made changes.
# Following line added for ClamAV
av_scanner = clamd:/var/run/clamav/clamd
# SpamBlocker.exim.conf.2.0-release #
# Runtime configuration file for DirectAdmin/Exim 4.24 and above #
######### IMPORTANT ########## IMPORTANT ########## IMPORTANT ########
# WARNING! Be sure to back up your previous exim.conf file before #
# attempting to use this exim.conf file. #
# Do may not use this exim.conf Exim configuration file unless you #
# make the required modifications to your Exim configuration #
# following the instructions in the README file included in this #
# distribution. #
# This is version "2.0 of the SpamBlocker exim.conf file as #
# distributed by NoBaloney Internet Services for DirectAdmin based #
# servers. #
# More information about NoBaloney.net may be found at: #
# http://www.nobaloney.net/ #
# More information about DirectAdmin may be found at: #
# http://www.directadmin.com/ #
# This Exim configuration file has been modified from the original #
# as distributed with Exim 4. The modifications have been made by: #
# Jeff Lasman #
# NoBaloney Internet Services #
# 1254 So. Waterman Ave., Suite 50 #
# San Bernardino, CA 92408 #
# [email protected] #
# (909) 266-9209 #
# The SpamBlocker exim.conf file has been modified from the original #
# exim.conf file as distributed with Exim 4, which includes the #
# following copyright notice: #
# Copyright (C) 2002 University of Cambridge, Cambridge, UK #
# Portions of the file are taken from the exim.conf file as #
# distributed with DirectAdmin (http://www.directadmin.com/), #
# Copyright (C) 2003 JBMC Software, St Albert, AB, Canada #
# Portions of this file are written by Jeff Lasman, of #
# NoBaloney Internet Services and are copyright as follows: #
# Copyright (C) 2004-2005 NoBaloney Internet Services, #
# San Bernardino, Calif., USA #
# The entire Exim 4 distribution, including the exim.conf file, is #
# distributed under the GNU GENERAL PUBLIC LICENSE, Version 2, #
# June 1991. If you do not have a copy of the GNU GENERAL #
# PUBLIC LICENSE you may download it, in it's entirety, from #
# the website at: #
# http://www.nobaloney.net/exim/gnu-gpl-v2.txt #
# The most recent version of this SpamBlocker exim.conf file may #
# always downloaded from the website at #
# http://www.nobaloney.net/exim/exim.conf.spamblocked #
# Whenever you change Exim's configuration file, you *must* remember #
# to HUP the Exim daemon, because it will not pick up the new #
# configuration until you do. However, any other Exim processes that #
# are started, for example, a process started by an MUA in order to #
# send a message, will see the new configuration as soon as it is in #
# place. #
# You do not need to HUP the daemon for changes in auxiliary files #
# that are referenced from this file. They are read every time they #
# are used. #
# It is usually a good idea to test a new configuration for #
# syntactic correctness before installing it (for example, by #
# running the command "exim -C /config/file.new -bV"). #
### MODIFICATION INSTRUCTIONS ########## MODIFICATION INSTRUCTIONS ###
# YOU MUST MAKE THE CHANGES TO THIS SpamBlocked exim.conf file as #
# documented in the README file. #
# The README file for this version is named: #
# README.SpamBlocker.exim.conf.2.0 #
# Specify your host's canonical name here. This should normally be the
# fully qualified "official" name of your host. If this option is not
# set, the uname() function is called to obtain the name. In many cases
# this does the right thing and you need not set anything explicitly.
# primary_hostname =
# Specify the domain you want to be added to all unqualified addresses
# here. An unqualified address is one that does not contain an "@" character
# followed by a domain. For example, "[email protected]" is a fully qualified
# address, but the string "caesar" (i.e. just a login name) is an unqualified
# email address. Unqualified addresses are accepted only from local callers by
# default. See the receiver_unqualified_{hosts,nets} options if you want
# to permit unqualified addresses from remote sources. If this option is
# not set, the primary_hostname value is used for qualification.
# qualify_domain =
# If you want unqualified recipient addresses to be qualified with a different
# domain to unqualified sender addresses, specify the recipient domain here.
# If this option is not set, the qualify_domain value is used.
# qualify_recipient =
# the next line is required to start the smtp auth script included
# in DirectAdmin
perl_startup = do '/etc/exim.pl'
# the next line is required to start the system_filter included in
# DirectAdmin to refuse potentiallly harmful payloads in
# email messages
system_filter = /etc/system_filter.exim
# next line to allow incoming email submission port 587
# see also check_recipient second ruleset
daemon_smtp_ports = 25 : 587
# SET SOME MEANINGFUL LIMITS
# OPTIONAL MODIFICATIONS:
# These defaults work for us; you may wish to modify them
# for your environment
message_size_limit = 500M
smtp_receive_timeout = 20m
smtp_accept_max = 100
message_body_visible = 3000
print_topbitchars = true
# ALLOW UNDERSCORE IN EMAIL DOMAIN NAME
# domains shouldn't use the underscore character "_" but some
# may. Because John Postel, one of the architects of the Internet,
# said "Be liberal in what you accept and conservative in what you
# transmit, we choose to allow underscore in email domain names so we
# can receive email form domains which use the underscore character
# in their domain name.
helo_allow_chars = _
# CHANGE LOGGING BEHAVIOR
# We weren't happy with the default Exim logging behavior through
# syslog; it didn't give us enough information. So we turned off
# syslog behavior and changed the logging behavior to give us what we
# felt was more helpful information. You may choose to delete or modify
# this section.
log_selector = \
+delivery_size \
+sender_on_delivery \
+received_recipients \
+received_sender \
+smtp_confirmation \
+subject \
+smtp_incomplete_transaction \
-dnslist_defer \
-host_lookup_failed \
-queue_run \
-rejected_header \
-retry_defer \
-skip_delivery
syslog_duplication = false
# These options specify the Access Control Lists (ACLs) that
# are used for incoming SMTP messages - after the RCPT and DATA
# commands, respectively.
acl_smtp_rcpt = check_recipient
# The following line added for ClamAV
acl_smtp_data = check_message
# define local lists
addresslist whitelist_senders = lsearch;/etc/virtual/whitelist_senders
addresslist blacklist_senders = lsearch;/etc/virtual/blacklist_senders
domainlist blacklist_domains = lsearch;/etc/virtual/blacklist_domains
domainlist whitelist_domains = lsearch;/etc/virtual/whitelist_domains
domainlist local_domains = lsearch;/etc/virtual/domains
domainlist relay_domains = lsearch;/etc/virtual/domains : localhost
domainlist use_rbl_domains = lsearch;/etc/virtual/use_rbl_domains
hostlist auth_relay_hosts = *
hostlist bad_sender_hosts = lsearch;/etc/virtual/bad_sender_hosts
hostlist bad_sender_hosts_ip = net-lsearch;/etc/virtual/bad_sender_hosts
hostlist relay_hosts = net-lsearch;/etc/virtual/pophosts : 127.0.0.1
hostlist whitelist_hosts = lsearch;/etc/virtual/whitelist_hosts
hostlist whitelist_hosts_ip = net-lsearch;/etc/virtual/whitelist_hosts
# If you want to accept mail addressed to your host's literal IP address, for
# example, mail addressed to "user@[111.111.111.111]", then uncomment the
# following line, or supply the literal domain(s) as part of "local_domains"
# above. You also need to comment "forbid_domain_literals" below. This is not
# recommended for today's Internet.
# DO NOT ALLOW HOST LITERALS
# These defaults work for us; you may wish to uncomment the line
# below and change the allow_domain_literals line below to true
# to allow domain literals in your environment
# local_domains_include_host_literals
# The following line prevents Exim from recognizing addresses of the form
# "user@[111.111.111.111]" that is, with a "domain literal" (an IP address)
# instead of a named domain. The RFCs still require this form, but it makes
# little sense to permit mail to be sent to specific hosts by their IP address
# in the modern Internet, and this ancient format has been used by those
# seeking to abuse hosts by using them for unwanted relaying. If you really
# do want to support domain literals, remove the following line, and see
# also the "domain_literal" router below.
allow_domain_literals = false
# No local deliveries will ever be run under the uids of these users (a colon-
# separated list). An attempt to do so gets changed so that it runs under the
# uid of "nobody" instead. This is a paranoic safety catch. Note the default
# setting means you cannot deliver mail addressed to root as if it were a
# normal user. This isn't usually a problem, as most sites have an alias for
# root that redirects such mail to a human administrator.
never_users = root
# DO HOST LOOKUP
# The setting below causes Exim to do a reverse DNS lookup on all incoming
# IP calls, in order to get the true host name. If you feel this is too
# expensive, you can specify the networks for which a lookup is done, or
# remove the setting entirely.
host_lookup = *
# DISALLOW IDENT CALLBACKS
# Exim may be set to make RFC 1413 (ident) callbacks for all incoming SMTP
# calls. You can limit the hosts to which these calls are made, and/or change
# the timeout that is used. If you set the timeout to zero, all RFC 1413 calls
# are disabled. RFC 1413 calls are cheap and can provide useful information
# for tracing problem messages, but some hosts and firewalls have problems
# with them. This can result in a timeout instead of an immediate refused
# connection, leading to delays on starting up an SMTP session. By default
# we disable callbacks for incoming SMTP calls. You may change
# rfc1413_query_timeout to 30s or some other positive number of seconds to
# enable callbacks for incoming SMTP calls.
rfc1413_hosts = *
rfc1413_query_timeout = 0s
# BOUNCE MESSAGES
# When Exim can neither deliver a message nor return it to sender, it
# "freezes" the delivery error message (aka "bounce message"). There are also
# other circumstances in which messages get frozen. They will stay on the
# queue forever unless one or both of the following options is set.
# This option unfreezes bounce messages after two days, tries
# once more to deliver them, and ignores any delivery failures.
ignore_bounce_errors_after = 2d
# This option cancels (removes) frozen messages that are older than five days.
timeout_frozen_after = 5d
# TRUSTED USERS
# if you must add additional trusted users, do so here; continue the
# colon-delimited list
trusted_users = mail:majordomo:apache:diradmin
# SSL/TLS cert and key
tls_certificate = /etc/exim.cert
tls_privatekey = /etc/exim.key
tls_advertise_hosts = *
#auth_over_tls_hosts = *
# ACLs #
begin acl
# ACL that is used after the RCPT command
check_recipient:
# to block certain wellknown exploits, Deny for local domains if
# local parts begin with a dot or contain @ % ! / |
deny domains = +local_domains
local_parts = ^[.] : ^.*[@%!/|]
# to restrict port 587 to authenticated users only
# see also daemon_smtp_ports above
accept hosts = +auth_relay_hosts
condition = ${if eq {$interface_port}{587} {yes}{no}}
endpass
message = relay not permitted, authentication required
authenticated = *
# allow local users to send outgoing messages using slashes
# and vertical bars in their local parts.
# Block outgoing local parts that begin with a dot, slash, or vertical
# bar but allows them within the local part.
# The sequence \..\ is barred. The usage of @ % and ! is barred as
# before. The motivation is to prevent your users (or their virii)
# from mounting certain kinds of attacks on remote sites.
deny domains = !+local_domains
local_parts = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
# local source whitelist
# accept if the source is local SMTP (i.e. not over TCP/IP).
# Test for this by testing for an empty sending host field.
accept hosts = :
# sender domains whitelist
# accept if sender domain is in whitelist
accept sender_domains = +whitelist_domains
# sender hosts whitelist
# accept if sender host is in whitelist
accept hosts = +whitelist_hosts
accept hosts = +whitelist_hosts_ip
# envelope senders whitelist
# accept if envelope sender is in whitelist
accept senders = +whitelist_senders
# accept mail to postmaster in any local domain, regardless of source
accept local_parts = postmaster
# accept mail to abuse in any local domain, regardless of source
accept local_parts = abuse
# accept mail to hostmaster in any local domain, regardless of source
accept local_parts = hostmaster
domains =+local_domains
# If the page you're using to notify senders of blocked email of how
# to get their address unblocked will use a web form to send you email so
# you'll know to unblock those senders, then you may leave these lines
# commented out. However, if you'll be telling your senders of blocked
# email to send an email to [email protected], then you should
# replace "errors" with the left side of the email address you'll be
# using, and "example.com" with the right side of the email address and
# then uncomment the second two lines, leaving the first one commented.
# Doing this will mean anyone can send email to this specific address,
# even if they're at a blocked domain, and even if your domain is using
# blocklists.
# accept mail to [email protected], regardless of source
# accept local_parts = errors
# domains = example.com
# deny so-called "legal" spammers"
deny message = Email blocked by LBL - to unblock see http://www.example.com/
# only for domains that do want to be tested against RBLs
domains = +use_rbl_domains
sender_domains = +blacklist_domains
# deny using hostname in bad_sender_hosts blacklist
deny message = Email blocked by BSHL - to unblock see http://www.example.com/
hosts = +bad_sender_hosts
# deny using IP in bad_sender_hosts blacklist
hosts = +bad_sender_hosts_ip
# deny using email address in blacklist_senders
deny message = Email blocked by BSAL - to unblock see http://www.example.com/
domains = use_rbl_domains
deny senders = +blacklist_senders
# By default we do NOT require sender verification.
# Sender verification denies unless sender address can be verified:
# If you want to require sender verification, i.e., that the sending
# address is routable and mail can be delivered to it, then
# uncomment the next line. If you do not want to require sender
# verification, leave the line commented out
#require verify = sender
# deny using .spamhaus
deny message = Email blocked by SPAMHAUS - to unblock see http://www.example.com/
dnslists = sbl.spamhaus.org
# deny using ordb
deny message = Email blocked by ORDB - to unblock see http://www.example.com/
dnslists = relays.ordb.org
# deny using sorbs smtp list
deny message = Email blocked by SORBS - to unblock see http://www.example.com/
dnslists = dnsbl.sorbs.net=127.0.0.5
# Next deny stuff from more "fuzzy" blacklists
# but do bypass all checking for whitelisted host names
# and for authenticated users
# deny using spamcop
deny message = Email blocked by SPAMCOP - to unblock see http://www.example.com/
hosts = !+relay_hosts
!authenticated = *
dnslists = bl.spamcop.net
# deny using njabl
deny message = Email blocked by NJABL - to unblock see http://www.example.com/
!authenticated = *
dnslists = dnsbl.njabl.org
# deny using cbl
deny message = Email blocked by CBL - to unblock see http://www.example.com/
!authenticated = *
dnslists = cbl.abuseat.org
# deny using all other sorbs ip-based blocklist besides smtp list
!authenticated = *
dnslists = dnsbl.sorbs.net!=127.0.0.6
# deny using sorbs name based list
domains =+use_rbl_domains
# rhsbl list is name based
dnslists = rhsbl.sorbs.net/$sender_address_domain
# accept if address is in a local domain as long as recipient can be verified
accept domains = +local_domains
endpass
message = "Unknown User"
verify = recipient
# accept if address is in a domain for which we relay as long as recipient
# can be verified
accept domains = +relay_domains
endpass
verify=recipient
# accept if message comes for a host for which we are an outgoing relay
# recipient verification is omitted because many MUA clients don't cope
# well with SMTP error responses. If you are actually relaying from MTAs
# then you should probably add recipient verify here
accept hosts = +relay_hosts
endpass
message = authentication required
authenticated = *
deny message = relay not permitted
# default at end of acl causes a "deny", but line below will give
# an explicit error message:
# ACL that is used after the DATA command
# Following lines added for ClamAV
check_mime:
warn decode = default
deny message = I don't accept this file type
condition = ${if match {${lc:$mime_filename}} {\N(\.exe|\.pif|\.bat|\.scr|\.lnk|\.com|.vbs)$\N} {1}{0}} deny message = Hiding of file extensions(CLSID hidden) is not allowed condition = ${if match {$mime_filename} {\N\{[a-hA-H0-9-]{25,}\}\N}{1}{0}} accept
# End lines added for ClamAV
check_message:
deny message = This email may contain virii ($malware_name)
malware = *
warn message = X-Antivirus-Scanner: Scanned with ClamAV
accept
# AUTHENTICATION CONFIGURATION #
# There are no authenticator specifications in this default configuration file.
begin authenticators
plain:
driver = plaintext
public_name = PLAIN
server_condition = "${perl{smtpauth}}"
server_set_id = $2
login:
driver = plaintext
public_name = LOGIN
server_prompts = "Username:: : Password::"
server_set_id = $1
# REWRITE CONFIGURATION #
# There are no rewriting specifications in this default configuration file.
# ROUTERS CONFIGURATION #
# Specifies how remote addresses are handled #
# ORDER DOES MATTER #
# A remote address is passed to each in turn until it is accepted. #
begin routers
# Remote addresses are those with a domain that does not match any item
# in the "local_domains" setting above.
# This router routes to remote hosts over SMTP using a DNS lookup. Any domain
# that resolves to an IP address on the loopback interface (127.0.0.0/8) is
# treated as if it had no DNS entry.
lookuphost:
driver = dnslookup
domains = ! +local_domains
ignore_target_hosts = 127.0.0.0/8
condition = "${perl{check_limits}}"
transport = remote_smtp
no_more
# This router routes to remote hosts over SMTP by explicit IP address,
# when an email address is given in "domain literal" form, for example,
# <user@[192.168.35.64]>. The RFCs require this facility. However, it is
# little-known these days, and has been exploited by evil people seeking
# to abuse SMTP relays. Consequently it is commented out in the default
# configuration. If you uncomment this router, you also need to comment out
# "forbid_domain_literals" above, so that Exim can recognize the syntax of
# domain literal addresses.
# domain_literal:
# driver = ipliteral
# transport = remote_smtp
# DIRECTORS CONFIGURATION #
# Specifies how local addresses are handled #
# A local address is passed to each in turn until it is accepted. #
# Local addresses are those with a domain that matches some item in the
# "local_domains" setting above, or those which are passed back from the
# routers because of a "self=local" setting (not used in this configuration).
# Spam Assassin
spamcheck_director:
driver = accept
condition = "${if and { \
{!def:h_X-Spam-Flag:} \
{!eq {$received_protocol}{spam-scanned}} \
{!eq {$received_protocol}{local}} \
{exists{/home/${lookup{$domain}lsearch{/etc/virtual/domainowners}{$value}}/.spamassassin/user_prefs}} \
} {1}{0}}"
retry_use_local_part
transport = spamcheck
no_verify
majordomo_aliases:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/${domain}/majordomo/list.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/list.aliases}}}}
domains = lsearch;/etc/virtual/domainowners
file_transport = address_file
group = daemon
pipe_transport = majordomo_pipe
no_rewrite
user = majordomo
majordomo_private:
driver = redirect
allow_defer
allow_fail
#condition = "${if eq {$received_protocol} {local} {true} {false} }"
condition = "${if or { {eq {$received_protocol} {local}} \
{eq {$received_protocol} {spam-scanned}} } {true} {false} }"
data = ${if exists{/etc/virtual/${domain}/majordomo/private.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/private.aliases}}}}
group = daemon
user = majordomo
domain_filter:
driver = redirect
allow_filter
no_check_local_user
condition = "${if exists{/etc/virtual/${domain}/filter}{yes}{no}}"
user = "mail"
file = /etc/virtual/${domain}/filter
pipe_transport = virtual_address_pipe
no_verify
uservacation:
driver = accept
condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/vacation.conf}{yes}{no}}
require_files = /etc/virtual/${domain}/reply/${local_part}.msg
transport = uservacation
unseen
userautoreply:
driver = accept
condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/autoresponder.conf}{yes}{no}}
transport = userautoreply
unseen
virtual_aliases_nostar:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/${domain}/aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}}}}
group = mail
unseen
#include_domain = true
virtual_user:
driver = accept
condition = ${if eq {}{${if exists{/etc/virtual/${domain}/passwd}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/passwd}}}}}{no}{yes}}
group = mail
transport = virtual_localdelivery
virtual_aliases:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/$domain/aliases}{${lookup{$local_part}lsearch*{/etc/virtual/$domain/aliases}}}}
group = mail
# This director handles forwarding using traditional .forward files.
# If you want it also to allow mail filtering when a forward file
# starts with the string "# Exim filter", uncomment the "filter" option.
# The check_ancestor option means that if the forward file generates an
# address that is an ancestor of the current one, the current one gets
# passed on instead. This covers the case where A is aliased to B and B
# has a .forward file pointing to A. The three transports specified at the
# end are those that are used when forwarding generates a direct delivery
# to a file, or to a pipe, or sets up an auto-reply, respectively.
userforward:
driver = redirect
allow_filter
check_ancestor
check_local_user
no_expn
file = $home/.forward
pipe_transport = address_pipe
reply_transport = address_reply
no_verify
system_aliases:
driver = redirect
allow_defer
allow_fail
data = ${lookup{$local_part}lsearch{/etc/aliases}}
# user = exim
localuser:
driver = accept
check_local_user
condition = "${if eq {$domain} {$primary_hostname} {yes} {no}}"
transport = local_delivery
# This director matches local user mailboxes.
# TRANSPORTS CONFIGURATION #
# ORDER DOES NOT MATTER #
# Only one appropriate transport is called for each delivery. #
# A transport is used only when referenced from a director or a router that
# successfully handles an address.
# Spam Assassin
begin transports
spamcheck:
driver = pipe
batch_max = 100
command = /usr/sbin/exim -oMr spam-scanned -bS
current_directory = "/tmp"
group = mail
home_directory = "/tmp"
log_output
message_prefix =
message_suffix =
return_fail_output
no_return_path_add
transport_filter = /usr/bin/spamc -u ${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}
use_bsmtp
user = mail
# must use a privileged user to set $received_protocol on the way back in!
#majordomo
majordomo_pipe:
driver = pipe
group = daemon
return_fail_output
user = majordomo
# This transport is used for local delivery to user mailboxes in traditional
# BSD mailbox format. By default it will be run under the uid and gid of the
# local user, and requires the sticky bit to be set on the /var/mail directory.
# Some systems use the alternative approach of running mail deliveries under a
# particular group instead of using the sticky bit. The commented options below
# show how this can be done.
local_delivery:
driver = appendfile
delivery_date_add
envelope_to_add
file = /var/mail/$local_part
group = mail
mode = 0660
return_path_add
user = ${local_part}
## for delivering virtual domains to their own mail spool
virtual_localdelivery:
driver = appendfile
create_directory
delivery_date_add
directory_mode = 700
envelope_to_add
file = /var/spool/virtual/${domain}/${local_part}
group = mail
mode = 660
return_path_add
user = "${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}"
quota = ${if exists{/etc/virtual/${domain}/quota}{${lookup{$local_part}lsearch*{/etc/virtual/${domain}/quota}{$value}{0}}}{0}}
## vacation transport
uservacation:
driver = autoreply
file = /etc/virtual/${domain}/reply/${local_part}.msg
from = "${local_part}@${domain}"
log = /etc/virtual/${domain}/reply/${local_part}.log
no_return_message
subject = "${if def:h_Subject: {Autoreply: ${quote:${escape:$h_Subject:}}} {I am on vacation}}"
text = "\
------ ------\n\n\
This message was automatically generated by email software\n\
The delivery of your message has not been affected.\n\n\
------ ------\n\n"
to = "${sender_address}"
user = mail
#once = /etc/virtual/${domain}/reply/${local_part}.once
userautoreply:
driver = autoreply
bcc = ${lookup{${local_part}} lsearch {/etc/virtual/${domain}/autoresponder.conf}{$value}}
no_return_message
subject = "${if def:h_Subject: {Autoreply: ${quote:${escape:$h_Subject:}}} {Autoreply Message}}"
user = mail
# This transport is used for delivering messages over SMTP connections.
remote_smtp:
driver = smtp
# This transport is used for handling pipe deliveries generated by alias
# or .forward files. If the pipe generates any standard output, it is returned
# to the sender of the message as a delivery error. Set return_fail_output
# instead of return_output if you want this to happen only when the pipe fails
# to complete normally. You can set different transports for aliases and
# forwards if you want to - see the references to address_pipe in the directors
# section below.
address_pipe:
driver = pipe
return_output
virtual_address_pipe:
driver = pipe
group = nobody
return_output
user = "${lookup{$domain}lsearch* {/etc/virtual/domainowners}{$value}}"
# This transport is used for handling deliveries directly to files that are
# generated by aliasing or forwarding.
address_file:
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
# This transport is used for handling autoreplies generated by the filtering
# option of the forwardfile director.
address_reply:
driver = autoreply
# RETRY CONFIGURATION #
# This single retry rule applies to all domains and all errors. It specifies
# retries every 15 minutes for 2 hours, then increasing retry intervals,
# starting at 1 hour and increasing each time by a factor of 1.5, up to 16
# hours, then retries every 8 hours until 4 days have passed since the first
# failed delivery.
# Domain Error Retries
begin retry
* * F,2h,15m; G,16h,1h,1.5; F,4d,8h
# End of Exim 4 configuration
I just ran an AV test from www.webmail.us/testvirus against the ClamAV running on the server. Two got through, 22 & 23, of the 25 sent. I assume that is related to my mime problem.
I do have a couple of other questions thought:
1. How do I keep the program up to date easily? Automatically?
2. How do I keep the signatures up to date automatically?
3. Is there anybody that you pay for this service?
A proper ClamAV install should be set up to update itself automatically.
However I haven't read what you've done, so you should probably check to make sure you've got a cronjob somewhere to do that. Perhaps someone else can tell you exactly where to look.
You don't pay anyone for ClamAV; it's an open source project, free as in beer; free as in speech.
However you can donate work, money, or equipment, or buy from the ClamAV store.
The information is here.
That's good to know. I followed the directions. There were no errors except the problem when I added the mime acl. The test came out with 2 coming though exactly like the How-To said should happen. Therefore it is working and the only thing remaining are:
- Find a way to verify updates are actually happening.
- Find out why the mime acl isn't working right for me.
I have it running by analyzing and the code in check_mime. It now blocks the .com, .exe, etc., except instead of the message I set, I get a 550 Administrative Phohibition.
Virus test:
1. I still get the two through during the test that it said that I would when it is working properly. The ones that get through are:
Test #22: (Non-Virus): Test for the "Partial (Fragmented) Vulnerability". <B>This does not include the EICAR virus</B>, however your mail server should still block this since a virus can use this technique to break itself into multiple emails, bypassing virus scanners, and reassembling itself in your inbox. **
Test #23: (Non-Virus): Attachment with a CLSID extension which may hide the real file extension. <B>This does not include the EICAR virus</B>, however your mail server should still block this since the CLSID technique can be used to hide the true extension of a malicious file. ***
I'm a little surprised the second one gets through because in theory the check_mime area looks for that, but then then the How-To said two would get through, so I guess this is as good as it gets. It is now fully implemented to the How-To.
