CNAME does not work
alexducatti
Portugal
I host ducatti.it and use the DA server to just handle DNS.
I have MX records which work fine, but the defined CNAME record doesn't work at all.
The "NAME" collum is mail.ducatti.it and "VALUE" is ghs.google.com.
What is wrong?
Should I delete any "A" or "NS" record ?
Should "NAME" is only the word "mail" or should be "mail.ducatti.it." - with a dot at the end?
I have tried everything !!!
Any idea ?
Name walue can me mail or mail.ducatti.it. result will be the same :) As I understand - you want to change the MX record, so delete the old record and add the new. Good luck. :)
This is the actual configuration.
What should I change?
ducatti.it A 194.177.96.153
ftp A 194.177.96.153
localhost A 127.0.0.1
pop A 194.177.96.153
ducatti.it. NS ns1.ion-mnt.net
ducatti.it. NS ns2.ion-mnt.net
ALT1.ASPMX.L.GOOGLE.COM. MX 50
ALT2.ASPMX.L.GOOGLE.COM. MX 50
ASPMX.L.GOOGLE.COM. MX 40
ASPMX2.GOOGLEMAIL.COM. MX 60
ASPMX3.GOOGLEMAIL.COM. MX 60
ASPMX4.GOOGLEMAIL.COM. MX 60
ASPMX5.GOOGLEMAIL.COM. MX 60
mail.ducatti.it. CNAME ghs.google.com.
So you just need
As I see - mail.ducatti.it is working fine now :)
Hey, it's working :) Maybe something wrong with your ISP DNS server. Take a look at the screenshot (attachment).
