good day;
i need your help to understand this problem
ive setup a cron job in the cron file to run a php file every 23 hours :
* */23 * * * /usr/local/bin/php /home/virys/domains/s3bay.com/public_html/cron/autoflash.php
problem is that although the cron run every 23 hours - ok - but after it is started it keep running the php file every 5 minutes or so -
no other cron is set on cron file or anywhere ! so im puzzled
if you have got a clue - let me know
with thanks
ray
with thanks
ray
