CSF Plus LFD Not Cleaning Up properly After Uninstall
topdog
First off I am running DA 1.33.7 and CentOS5.3 32-bit. I uninstalled CSF and LFD from configserver.com a while ago but the link for the LFD service is still within DirectAdmin's service moniter page.
How do I get rid of that link? And has anyone else experienced this issue before?
LFD is a service so it should be in the monitored section as well..... although it should not be a link for it there... just being monitored like the rest.
the configuration link should be in "Extra's" called "ConfigServer Firewall & Security"
The thing is that LFD is uninstalled completely. So the link and the service itself should have been removed but it wasn't.
Did you fix this?
I'm having the same problem and getting system alerts that the lfd service is down after I ran the uninstall.sh.
It also didn't remove the plugin properly from DA so I removed that manually.
Thanks in advance.
