CSF starting problem because of ip6tables
dm800pvr
I have a trouble starting the csf because of ip6tables error:
Starting csf:You have an unresolved error when starting csf:
Error: /sbin/ip6tables (ip6tables binary location) does not exist!, at line 64 i
You need to restart csf successfully to remove this warning, or delete /etc/csf/
Please advice,
Also I have centos 6-64 bit with
whereis ip6tables
ip6tables: /sbin/ip6tables /usr/share/man/man8/ip6tables.8.gz
Please show results
ls -la /sbin/ip6tables
If you don't have IPv6 you can disable IPv6 in /etc/csf/csf.conf and remove /etc/csf/csf.error, then restart csf.
