custombuild and custom hook post script
ccto
Hong Kong
Hello All,
I tried to put a file - /usr/local/directadmin/custombuild/custom/hooks/modsecurity_rules/post/xxxx.sh (owned by root.root , permission 750) . My script will update /etc/modsecurity.d/REQUEST-900-EXCLUSION-RULES-BEFORE-CRS.my.conf automatically after modsecurity rule updates.
If I run "da build modsecurity_rules" , the above hook post script worked fine.
If I run "da build update_versions" , it includes modsecurity_rules update, however, the above hook script did not run.
Is it expected?
Thank you
Regards
George
yes, it still trigger the hook only from the main command input, child process won't trigger any hooks at all.
Copy your hook to /usr/local/directadmin/custombuild/custom/hooks/update_versions/post/xxxx.sh
Or use symlinks for folders. Do not symlink xxxx.sh, as Directadmin won't see such a script.
