Customize Evolution Skin logo not working? *not cache problem*
oscars
So i was wondering how does the Customize Evolution Skin works.
I have edited Default, For dark mode & sidebar layout, Symbol, and Symbol for dark mode.
so far symbols works out of the box but I don't know if the login it's attached to this variable in order to see the logo at the login page.
It would be good to have some doc about it (either recommended size/format for the images)
I was able to find:
But in my case I'm not looking to change all the login page, just to update the logo that it's already built in at the admin with the login or do I need to manually overwrite paths? (This means that maybe in every update I will need to do it again right?).
Do anyone knows if the logo from the "Customize Evolution Skin" applies to login html as my understanding it should be that way
Edit:
It seems I need to overwrite pahts (https://docs.directadmin.com/directadmin/skins-and-templates/customizing-login-page.html) for the images but the if we upload that logo already from the admin it should be taken from there right? if isn't intended that way I may request that feature but as I said I don't know how it works
