Installing directadmin 1.63.1 (not beta) by just triggerring DA installation with auto mode:
and apache is not working with the following message (tried to rebuild but the same error happen):
When I try to rebuild apache it was just stuck with this message:
I wish to have fewer issues like this, especially new installation for production. You guys should test this before release because this is not even a beta release or using custom install.
My operating system:
Debian 11
bash <(curl -Ss https://www.directadmin.com/setup.sh || wget -O - https://www.directadmin.com/setup.sh) auto
systemctl status httpd
● httpd.service - The Apache HTTP Server
Loaded: loaded (/etc/systemd/system/httpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2021-11-09 08:39:24 +08; 36min ago
Main PID: 218502 (code=exited, status=1/FAILURE)
CPU: 23ms
Nov 09 08:39:24 hostname.server.com ystemd[1]: Starting The Apache HTTP Server...
Nov 09 08:39:24 hostname.server.com httpd[218502]: httpd: Syntax error on line 222 of /etc/httpd/conf/httpd.conf: Syntax error on line 23 of /etc/httpd/conf/extra/httpd-vhosts.conf: Could not open configuration file /etc/httpd/conf/ips.conf: No such file or directory
Nov 09 08:39:24 hostname.server.com systemd[1]: httpd.service: Main process exited, code=exited, status=1/FAILURE
Nov 09 08:39:24 hostname.server.com systemd[1]: httpd.service: Failed with result 'exit-code'.
Nov 09 08:39:24 hostname.server.com systemd[1]: Failed to start The Apache HTTP Server.
root@sun:~# /usr/local/directadmin/custombuild/./build apache
Enabling http2 in directadmin.conf.
Debian 11
Compiled on 'Linux 64-bit'
Compile time: Nov 7 2021 at 10:40:59
Timestamp: '1636281653'
Compiled with IPv6
Static binary: yes
commit sha: 855dac374a755307b35526a1b2d9f4327e03fac7
OS slug: linux_amd64
package: directadmin_855dac374a755307b35526a1b2d9f4327e03fac7_linux_amd64.tar.gz
gettext support: yes
gettext path: /usr/local/directadmin/data/lang
