da build update_versions (it will auto update DA too, but not mentioned in da build versions)
ccto
Hong Kong
Hello All,
We are currently using DirectAdmin 1.675 bcd6e3bf4a4dbfaeb423aae49ad2a0fd77206d7f
When we run "da build update_versions"
we expect it will update everything inside "da build versions" (in my case, simply ProFTPd1.3.9)
However, when the task ("da build update_versions") completed, a few seconds later, DA changed from 1.675 to 1.676 automatically.
Is it normal?
We are not very well/confident with Dovecot 2.4 series at the moment.
Also, quite a lot of email related change in 1.676 .
Thank you for your kind attention.
Regards
George.
The CustomBuild stopped reporting DirectAdmin updates and command da build update_version stopped updating DirectAdmin since DirectAdmin version 1.666.
I think in this case it just so happened that DirectAdmin automatic update was performed around the same time when CustomBuild installing updates.
