DA Exim authenticaton problem
mtes
Hi everyone,
I have da_exim-4.43-1 on Fedora Core 2 and really big problem with sending emails. In mainlog it occures as
"plain authenticator failed for (here client id) 535 Incorrect authentication data"
exim.pl works ok, I checked it many time using log_str sub included in it.
in exim.conf I have
begin authenticators
plain:
driver = plaintext
public_name = PLAIN
server_condition = "${perl{smtpauth}}"
server_set_id = $2
login:
driver = plaintext
public_name = LOGIN
server_prompts = "Username:: : Password::"
server_set_id = $1
Mtes
DA uses pop-before-smtp, so you need to have logged on to POP3 at least during the pas 15 minutes in order to send messages. Therefore, SMTP doesn't need a passsword.
Although this is abit insecure, since your password is sent in PLAIN test when logging in to POP3.
TO start pop-before-smtp:
/sbin/service da-popb4smtp start
You might be able to sue SMTP authentication if you start the saslauthd daemon (I haven't checked this).
/sbin/service saslauthd start
