dannyman1234
- Mar 2, 2010
Hi, I installed fedora 12. fine and YUM was still working, now after i installed DA:
is gives me:
Type: /sbin/service httpd restart
./directadmin: error while loading shared libraries: libssl.so.6: cannot open shared objec t file: No such file or directory
So i want to to install libssl, but then i get:
CRITICAL:yum.cli:Config Error: Error accessing file for config file:///etc/yum.conf
The file exists and here are the contents
My yum.conf file
[main]
cachedir=/var/cache/yum/$basearch/$releasever
keepcache=0
debuglevel=2
logfile=/var/log/yum.log
exactarch=1
obsoletes=1
gpgcheck=1
plugins=1
installonly_limit=3
It seems after installing DA, the problems started. Also the installation guide is by far not complete.
Look here:
http://www.directadmin.com/installguide.html
is saids you need to install this in step 1:
SSH installed, gcc and g++ installed.
Im sorry but you should also install these:
*** flex is required for compiling php, please install flex (yum install flex)***
*** bison is required for compiling, please install bison (yum install bison)***
*** cannot find /usr/include/openssl/ssl.h. Please make sure openssl-devel is installed (yum install openssl-devel) ***
*** cannot find /usr/bin/patch. Please make sure that patch is installed (yum install patch) ***
*** cannot find /usr/bin/make. Please make sure that patch is installed (yum install make) ***
yum install perl // perl installation
yum install bind // bind installation
Then you can start to install, but still problems. At least on fedora 12.
Regards
Danny
is gives me:
My yum.conf file
[main]
keepcache=0
debuglevel=2
exactarch=1
obsoletes=1
gpgcheck=1
plugins=1
installonly_limit=3
Look here:
Regards
Danny
