DA not started? - help
dustin0
I recently bought DA through my vps and i cant get it working right. It was done on a clean OS install and all seemed to be going good but i cant access the cpanel here are the last outputs via control panel
Link I should be going to:http://64.79.219.118:2222
## INSTALL_COMPLETE
## ACCOUNT_INFO
The following information has been set:
Admin username: admin
Admin password: ***edited***
Admin email: [email protected]
Server IP: 64.79.219.118
Server Hostname: server.dustin0.net
To login now, follow this link:
and enter your Admin username and password when prompted.
You should now visit http://admin.site-helper.com and http://www.directadmin.com/newinstall.html to learn how to get started.
Thank you for using DirectAdmin. Should you have any questions, don't hesitate to contact us at [email protected]
## REPORT_END
Permissions set
Have you followed this instruction:
Special notice for VPS/VDS installs:
After the install, add:
ethernet_dev=eth0:devicename
to /usr/local/directadmin/conf/directadmin.conf.
Replace devicename with the FULL devicename reported by ifconfig. If your VDS/VPS system emulates eth0, then you may skip this step.
