Da problem
What OS are you using, what error is displayed (if any) what have you done to try and resolve this?
Have you checked to see what happens if you simply do http://ip ?
Have you checked to see if DA is actually running on the box?
Regards,
Onno Vrijburg
Regards,
Onno Vrijburg
Redhat
and if I ckeck http://ip i see the test page of apache
So we know you can reach your server and that apache is running.
What we don't know is if DA is running or not.
Log in through your shell as any user.
Then:
ps waux | grep directadmin
What's the output?
[root@81 root]# ps waux | grep directadmin
root 1722 0.0 0.0 716 44 ? S 15:55 0:00 /usr/local/directadmin/da-popb4smtp
root 8521 0.0 1.1 3632 676 pts/0 S 18:44 0:00 grep directadmin
DirectAdmin isn't running.
Try to start it this way:
/etc/rc.d/init.d/directadmin start
and then try the grep again.
[root@81 root]# /etc/rc.d/init.d/directadmin start
Starting DirectAdmin: [ OK ]
But i still doesn't work
Hi, if you let me have access to the box I'll have a look. Send me a PM with the login info + server IP if you want me to help solve this problem.
Regards,
Onno
