Somehow DA_FOREGROUND_CUSTOMBUILD environment variable does not work. Running setup like:
DA_FOREGROUND_CUSTOMBUILD=true ./setup.sh <client_id> <license_id> <interface> <ip address>
will install custombuild options in the background. We have an options.conf placed in a empty /usr/local/directadmin/custombuild with all the settings we need for the build.
We tested this part of the setup in a bash script (test.sh) and it works without a problem.
if [ -z "${DA_FOREGROUND_CUSTOMBUILD}" ]; then
echo "DA_FOREGROUND_CUSTOMBUILD=false"
else
echo "DA_FOREGROUND_CUSTOMBUILD=true"
fi
[srv1 ~]# DA_FOREGROUND_CUSTOMBUILD=true ./test.sh
But somehow in the setup.sh it does not work. Everytime we run "DA_FOREGROUND_CUSTOMBUILD=true ./setup.sh", custombuild runs in the background and shows the echo line "You will receive a message in the DirectAdmin panel when background installation finalizes."
Because we use ansible to deploy DA on remote hosts, we need to monitor the progress of the custombuild.
setup.sh custombuild part
${DA_PATH}/custombuild/build update >> ${DA_PATH}/custombuild/install.txt 2>&1 &
${DA_PATH}/custombuild/build all d >> ${DA_PATH}/custombuild/install.txt 2>&1 &
echogreen "You will receive a message in the DirectAdmin panel when background installation finalizes."
else
${DA_PATH}/custombuild/build all d | tee ${DA_PATH}/custombuild/install.txt
fi
else
fi
else
fi
